Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
06-11-2006, 09:32 | #1772 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: Republic of Kosova Age: 54
Member: 189304 Status: Offline Sonork: 100.1614605 Thanks Meter: 40 | Quote:
06-11-2006, 23:21 | #1774 (permalink) |
Crazy Poster Join Date: May 2005 Location: New Zealand
Member: 144686 Status: Offline Thanks Meter: 1 | nokia 6101 raio not working Hey guys can someone help me radio not woking on 6101, I have updated the software already and have done factory reset, but still no luck. |
06-12-2006, 08:59 | #1777 (permalink) |
Junior Member Join Date: Mar 2006
Member: 249694 Status: Offline Thanks Meter: 0 | i have dongle 1 st boot error hi i have problem with ufsx dongle when i connect to pc it will show 1st boot error during flash there is some h/w problem with dongle how to solve this dongle problem plz reply me as early as possible it all leds working power supply ok |
06-12-2006, 09:29 | #1778 (permalink) | |
Freak Poster Join Date: Jul 2005 Location: cebu Age: 43
Member: 164237 Status: Offline Thanks Meter: 12 | Quote:
there are several glue remover for it that is available..but the thing is its hazardous to health. you can manually remove it by being patient and with good steady hands.. make sure you mount your board on a steady base ( e.g. metal plate with clamp ) then put heat sink on other ic near to the ic to be removed... while applying heat on the glued ic, scalp the excess glue around the ic gently. it will soften when being heated until such a time that the remaining glue is only inside the ic. apply gentle force to remove the glued ic.. it may take several times until it will be remove.. apply liquid flux.. let it cool down for 1minute after every 2-3mins of hot air... after removing the glued ic, scalp the remaining glue while applying moderate heat.. i tried it on 6600, 1100, 2300, 6230, 6260 and 3230 with quite high success rate only at 1100 and 2300 did i experience setbacks....B.R. and Good Luck! | |
06-12-2006, 09:32 | #1779 (permalink) | |
re install ufsx and driver and install flash files at the same directory as where did you install your ufsx..B.R. | |
06-12-2006, 10:01 | #1780 (permalink) |
Crazy Poster Join Date: Oct 2004 Location: Kinshasa
Member: 88765 Status: Offline Thanks Meter: 0 | Dos anybody have the solution for solving the problem of N90 and 3250 always on offline mode even after inserting the simcard??? I have two of them with the same problem. If any body have the solution plz post... Need urgent!!! |
06-12-2006, 13:35 | #1782 (permalink) | |
06-12-2006, 14:19 | #1784 (permalink) | |
Freak Poster Join Date: Aug 2004 Age: 45
Member: 77076 Status: Offline Thanks Meter: 7 | Quote:
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
