Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
06-26-2009, 19:48 | #6331 (permalink) |
Freak Poster Join Date: Oct 2008
Member: 887350 Status: Offline Thanks Meter: 12 | |
06-26-2009, 21:22 | #6332 (permalink) |
Junior Member Join Date: Nov 2008
Member: 909622 Status: Offline Sonork: [email protected] Thanks Meter: 8 | I have a issue ,6300 imei not showing *#06# = i want to input a new imei and it must work with the code (*#06#) to check imei , please can you give some guide line how can i overcome this issue... also the other problem is if i dont use it for few minutes phone is auto off. Battery is Fine, what can be the possible reason and how it can be resolved. pls explain... Thank you in advance |
06-27-2009, 11:48 | #6335 (permalink) |
Major Poster Join Date: Jul 2006 Location: gingee Age: 43
Member: 317953 Status: Offline Thanks Meter: 4 | nokia 6020 flash Getting MCU ID MCU ID: 0x2142 FLASH ID0: 882E0020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... not flasing |
06-27-2009, 12:55 | #6340 (permalink) |
Crazy Poster Join Date: May 2006
Member: 271970 Status: Offline Thanks Meter: 0 | Hello pros, my N82 Map stopped navigating. Says license expired. Someone help me with license. Email me at [email protected]. Do i need map software or just the license? |
06-28-2009, 10:34 | #6341 (permalink) |
Major Poster Join Date: Jun 2009
Member: 1058584 Status: Offline Thanks Meter: 4 | help my hand is nokia 6630 smartmovie v4.15 id is 355677007950534 my serial key is 61877 but after registration it connect with internet and says your code is unauthorized access plz contact lcg support key please solve my problem. |
06-28-2009, 13:22 | #6343 (permalink) |
Junior Member Join Date: Aug 2008
Member: 840436 Status: Offline Sonork: 457845 Thanks Meter: 5 | problem with p910i hi friend. i have p910i with a one problem is that when ever i run jar file it give error then close the application error is . (Jes-407-Javax-microedition Icduil @1420d6 ) plz reply me thanks |
06-28-2009, 13:56 | #6345 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1063399 Status: Offline Sonork: eighster Thanks Meter: 0 | Please help hello, can you please help me unlock my fone? phone model: sagem my150x the IME is 355726015253348 please help me because my other phone is broken and i really need to to unlock this phone so i can keep in touch with my family. thank you so much! |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
