Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
07-05-2007, 06:00 | #3724 (permalink) |
Junior Member Join Date: Mar 2007
Member: 471026 Status: Offline Sonork: Asif Raza Thanks Meter: 0 | I have 6600 The problem is that the other functions are ok but figer are not working and the galery opens but the folders in the galery did not opens I flashed the set and also formated the user area but nothing doing Plz helpppppppppppppppp me Thanks a lotttttttttt |
07-05-2007, 06:25 | #3725 (permalink) |
Junior Member Join Date: Aug 2006
Member: 326560 Status: Offline Thanks Meter: 0 | hi i had installed pheonix and used it to connect my ph [n changed a few settings but did not update d firmware as i just wanted to c how it worked ] and thn uninstalled every thing ...... !! now i reinstalled d nokia pc suite but my ph is not detected !! i hav already used d nokia pc suite cleaner to clean al d traces but stil its not detecting my ph. please help. thanx |
07-05-2007, 06:26 | #3726 (permalink) |
Crazy Poster Join Date: Oct 2006
Member: 374164 Status: Offline Thanks Meter: 1 | sir i have a 6600 with white screen i flash it using jaf after flash writing this message indicates... Boot is ready... FLASH ID0: 2000C088 -> SEC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 2000C088 -> SEC Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 2000C088 -> SEC Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 2000C088 -> SEC Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x88C00020 Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_st_i.fia Loader version: 04.3D.00 -> Revision: 0007 Loader size is 0x57F8; Loader chk: 1a Loader is ready... P-key nokia module version 01.00 MSID: 8417C0071DF8CBD453C7EAE436 MSID decoded: 3E4EBAF70056E1B5A9000000 FAID: 0AF1F9B4B2D74F6B75A0D0CC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_cbusb.fia Loader version: 04.3D.00 -> Revision: 0007 Loader size is 0x2020; Loader chk: 2c Additional Loader is ready... Operation took 0 minutes 24 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 007FFFFF... Erasing area: 04000000 - 046FFFFF... Erasing area: 06000000 - 066FFFFF... Erasing area: 047C0000 - 047EFFFF... Operation took 3 minutes 34 seconds... Writing... MCM Register OK Perm. Data Restore OK Operation took 3 minutes 4 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.34 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.3D.00 -> Revision: 0007 Boot size is 0x1090 Boot is ready... FLASH ID0: 2000C088 -> SEC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 2000C088 -> SEC Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 2000C088 -> SEC Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 2000C088 -> SEC Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x88C00020 Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_st_i.fia Loader version: 04.3D.00 -> Revision: 0007 Loader size is 0x57F8; Loader chk: 1a Loader is ready... P-key nokia module version 01.00 MSID: 846BC219BA7323C9278CE244BB MSID decoded: 3E4EBAF70056E1B5AA000000 FAID: 1805072859628410040386EC Operation took 0 minutes 24 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 02000000 - 020DFFFF... Operation took 0 minutes 8 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 20 seconds... Restarting MCU... Flashing Done! Operation took 8 minutes 39 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! what can i do please help me sir |
The Following User Says Thank You to nijo For This Useful Post: |
07-05-2007, 15:11 | #3727 (permalink) |
Member: 374164 Status: Offline Thanks Meter: 1 | i have 7610 with white screen when it switch on the screen and LEDs always on position upto removing the battery ... i flash the set using JAF box then some errors displayed ... please help me sir Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE605220.C1 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.3D.00 -> Revision: 0007 Boot size is 0x1090 Boot is ready... FLASH ID0: EC00F822 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC00F822 -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: EC00FA22 -> ST Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.3D.00 -> Revision: 0007 Loader size is 0x7E70; Loader chk: 46 Loader is ready... P-key nokia module version 01.00 MSID: 848AA8A2EF4D9EE8CC56650788 MSID decoded: 3E4EBAF70041F6ABA9000000 FAID: AFC32BBC03C1F76564E6C4E9 Operation took 0 minutes 23 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 00FFFFFF... Erasing area: 02000000 - 0287FFFF... Erasing area: 02FC0000 - 02FEFFFF... Operation took 4 minutes 1 seconds... Writing... Error in datablock chk Error in datablock chk Error in datablock chk Perm. Data Restore OK Operation took 3 minutes 54 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605220.02 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.3D.00 -> Revision: 0007 Boot size is 0x1090 Boot is ready... FLASH ID0: EC00F822 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC00F822 -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: EC00FA22 -> ST Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.3D.00 -> Revision: 0007 Loader size is 0x7E70; Loader chk: 46 Loader is ready... P-key nokia module version 01.00 MSID: 84C7B04C4E061376AD0F386D6C MSID decoded: 3E4EBAF70041F6ABAA000000 FAID: E26E2036061415A1A5355DB0 Operation took 0 minutes 27 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 02A00000 - 02C9FFFF... Operation took 0 minutes 27 seconds... Writing... Error in datablock chk Perm. Data Restore OK Operation took 0 minutes 24 seconds... Restarting MCU... Flashing Done! Operation took 10 minutes 11 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! |
07-05-2007, 15:15 | #3728 (permalink) |
Junior Member Join Date: Apr 2007
Member: 484038 Status: Offline Thanks Meter: 3 | Dear Friends, I am using nokia 6600 and i am using N private application to store my personal messages and now i bought Nokia N73 and i like to transfer all my messages frm Inbox and messages frm Nprivate to the Nokia N73 plz tell me how to transfer these messages. Plz hepl me |
07-06-2007, 09:02 | #3730 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 299902 Status: Offline Thanks Meter: 20 | l have a 6230i which will only charge when the phone is off ,if you try when it is on you get not charging the battery is okay the center pin is okay l flaashed the pm checked the R22 any help please |
07-06-2007, 09:15 | #3731 (permalink) |
No Life Poster Join Date: Dec 2003 Location: in the center of the heart
Member: 46125 Status: Offline Thanks Meter: 59 | very urgent please please have many nokia 6280 ..the phones are untouched new when i put in the simcard it says ACCEPT AND REJECT... when i select REJECT ..the phone switches off someone also told me to unlock and i also unlocked it but no progress if i select ACCEPT then it says insert sim card ..which is offline mode if i select REJECT then the phone shuts down ..which is online mode i also did all possible software upgrading downgrading erasing etc etc and also changed the sim small silver IC but still no progress please can u give me a correct solution to this problem???? thanks to u br |
07-06-2007, 14:20 | #3732 (permalink) |
Junior Member Join Date: Jul 2007
Member: 541090 Status: Offline Thanks Meter: 1 | i have a 6210 nokia whose mic is not working any help will be greatly appreciated pictures would also help as i am new also would any one tell me how to test the mic without having to make calls because that is one costly option |
07-06-2007, 14:31 | #3733 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Manama / BAHRAIN
Member: 100592 Status: Offline Sonork: 1578498 Thanks Meter: 245 | Quote:
its sim jacket or sim IC problem better to check in hardware best of luck & Best Regards GSMCrazy1 | |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
