Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
08-20-2007, 20:42 | #3826 (permalink) | |
Major Poster Join Date: Jan 2007
Member: 438710 Status: Offline Thanks Meter: 0 | Quote:
dear friend, before flashing your N70 try this also remove your battery and mem.card put it back the battery press and hold three buttens given below
dont release any button untill you see a formatt command. let me know thw updates | |
08-20-2007, 21:16 | #3827 (permalink) | |
Dear Friend, you are in wronk place here the discussion only about mobile phone | |
08-27-2007, 03:15 | #3834 (permalink) |
Junior Member Join Date: Aug 2007
Member: 573337 Status: Offline Thanks Meter: 0 | Low signal I have a nokia 6210. It has started to have a very low signal. I have read some posts and it seems it might be the ccont, cobba, aerial switch, hagar. WHERE are these parts? Where is a diagram that shows me where the ccont, cobba, switch, hagar are? The service manuals have scematics and part numbers. Neither tell me where the ccont, coba, switch, hagar actually are!!!? please help! |
08-27-2007, 04:29 | #3835 (permalink) |
Freak Poster Join Date: Feb 2006 Location: india.coimbatore Age: 47
Member: 233492 Status: Offline Thanks Meter: 93 | How to reformat Nokia 7700 and 7710? In case of serious problems with your Nokia 7700/7710 (if e.g. your phone doesn't start or it is very unstable) use the following method to reformat the device. Please, be aware that this function brings your phone back to a factory state, i.e. it removes all applications, files and data. Disconnect the charger and remove the battery. Wait for about ten seconds and insert the battery to start the device. When you see the NOKIA welcome screen, immediately press and hold two lower keys on the left side (the [= key and the Menu key) and shortly after that press and hold the second key from the top on the right side on the phone. Confirm that you want to format. Formatting will start. |
08-30-2007, 09:18 | #3837 (permalink) |
Member: 575890 Status: Offline Thanks Meter: 0 | The mic of my nokia 5200 is not working whether it is call, audio record or video record... even if i use headset the mic still doesnt work, they cant hear me... is there anyway to fix this?? help me please... |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
