Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 02-08-2006, 12:20   #421 (permalink)
Member: 77076
Thanks Meter: 7
Originally Posted by nolyboy
did you downgrade it or something?? do you have jaf flasher i use this one on that unit
no i did not downgrade it,i just copied the flash from a working phone and did complete flash using twister,and i dont have a jaf flasher,so what do i do now?tanx
Old 02-08-2006, 12:27   #422 (permalink)
Member: 77076
Thanks Meter: 7
[QUOTE=nolyboy]search it here in the forum there are many diagram about n gage just full flash
i have searched before posting,but kindly give me the link to particulat thread on the forum to check.And how about the ngage that reboots?I have flashed full yet it did not work.
Old 02-08-2006, 16:10   #423 (permalink)
Crazy Poster
Member: 230396
6230i flashing problem
Detected: V 03.62 04-Nov-05 RM-72 GSM P1.1 (c) NMP.
FLASH_FILE_MM_TYPE: TIKU EIJA SSR [NAND]
1st Boot Ok, TIKU, UPP: 1052
Fl0: 0x00000000-0x00FFFFFF,00EC22E8,Sam K8S2815
Fl1: 0x02000000-0x03FFFFFF,00EC0010,Sam OneNAND256
Algorithm: te_essr.fia, Ver: 4.49.0
Warning: Must be Used File for OneNAND Chips (M)
Erasing Mass Memory
Erasing Error: MM_2B_2, Time: 00:11
Process Failed, Repowering Mobile
Old 02-08-2006, 16:20   #424 (permalink)
fatho's Avatar
Member: 175344
Thanks Meter: 3
Erasing Mass Memory
use flash file 3.62 for new hardware id.
just search.
Old 02-08-2006, 16:25   #425 (permalink)
Member: 230256
My 9500 cover screen sometimes becomes fuzzy and freezes. However, the desktop works fine. Does this entails major repair? Pls. advise...Thanks.
Old 02-08-2006, 16:35   #426 (permalink)
Crazy Poster
Member: 230396
@ fatho
thanks for rep.. i have use old & new but same aroor plz any idea ?
Old 02-08-2006, 16:38   #427 (permalink)
ogc
Member: 52073
Thanks Meter: 6
can you help me with one code or one way to unblock my cell phone (nokia1100) pls.
Old 02-08-2006, 17:19   #428 (permalink)
Crazy Poster
Member: 230396
hello
@ Fatho thanks sir
thanks.you very much new hw id good work...
Old 02-08-2006, 18:32   #429 (permalink)
Member: 186283
Thanks Meter: 2
Unhappy 3310
Pls can u help me out with a dead 3310 whose positive & negative battery terminals are shorting (i.e. reading continuous with a multimeter)
Old 02-09-2006, 03:21   #430 (permalink)
Member: 230447
Thanks Meter: 35
hey bro, can u help me about my S.E K300i phone the joystic not functioning well, i try to clean but nothing happen...plsss help
Old 02-09-2006, 06:47   #431 (permalink)
goffaman's Avatar
Member: 164237
Thanks Meter: 12
try first remove the power amp ..
Old 02-09-2006, 06:49   #432 (permalink)
goffaman's Avatar
Member: 164237
Thanks Meter: 12
it bet to replce it bec of wear and tear.. but for temporary solution, try removing it, clean it and put it back again
Old 02-09-2006, 06:51   #433 (permalink)
goffaman's Avatar
Member: 164237
Thanks Meter: 12
try to adjust the flex connector at the front cover.. you might need to tighten it a bit by putting paddings..B.R.
Old 02-09-2006, 06:52   #434 (permalink)
goffaman's Avatar
Member: 164237
Thanks Meter: 12
Originally Posted by moncef
3310 flash ok but can t power on please help
all hardware checked
thanks
replace flace ic..
Old 02-09-2006, 06:53   #435 (permalink)
goffaman's Avatar
Member: 164237
Thanks Meter: 12
replac flash ic.. sorry B.R.
post me your problem in motorola and let me give you the rite solution greeni222000 Motorola Hardware Repair 2138 01-15-2019 05:46
Post me your BB5 problem here.. Ill try to help with Pict ichal_spy Nokia Hardware & Hardware Repair 13 10-05-2014 10:23
!!!!post Me Your Hardware Problem!!!! Ustad rajab.Com Nokia Hardware & Hardware Repair 32 01-18-2013 08:37
post me your all 6600 problem tommobil2005 Nokia Repair Guide and FAQ 459 01-17-2011 12:23
Page generated in 0.41601 seconds with 9 queries
