Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
07-04-2008, 17:30 | #4460 (permalink) |
Junior Member Join Date: Jul 2008
Member: 806944 Status: Offline Thanks Meter: 0 | Hi I have Motorola V180 with FIDO. I want to unlock it. I did try P2k and unlocker with sucessful message. However, I still get 'please contact service provider'. Can anyone help to guide to unlock this phone. Thanks in advance. |
07-04-2008, 19:34 | #4461 (permalink) |
Junior Member Join Date: Sep 2006
Member: 351332 Status: Offline Thanks Meter: 0 | Hello, nokia 6111 does not play any kind of sound.No mp3,no aac, no amr. Just the keypad clicks.Microphone and speaker ok. latest filrmware,just flashed. How to fix it? Thank you very much |
07-04-2008, 19:37 | #4462 (permalink) |
Junior Member Join Date: Jan 2007
Member: 443254 Status: Offline Thanks Meter: 2 | heloo sir.. pls help me to solve the mic problem of my 3250. i changed the cable, mic. and after i ****ered the power ic also. but i can't solve that problem.. pls help me as quickly |
07-05-2008, 09:52 | #4465 (permalink) |
Freak Poster Join Date: Aug 2007 Age: 38
Member: 571038 Status: Offline Thanks Meter: 40 | you have to se if imei is ok if it is "????????????" then you have a problem because UEM is damaged . if the imei (UEM) is ok then it might be an hardware problem : filters and ringer ways !!! post back result pls !!! |
07-05-2008, 10:55 | #4468 (permalink) |
Junior Member Join Date: Jan 2008
Member: 692997 Status: Offline Thanks Meter: 1 | Problem! Here’s a technical question for you. How do I start up a new thread? I’ve been regularly logging onto the site with the intention of starting a new discussion because I wanted some advice and each time I can’t find the button to do it. Could this function not be loading up consistently? Incidentally, I’m looking to find a full 18 pin Samsung A200,R210connector, or something similar, to wire up a data transfer cable. It's an old model so I don't know where to try next. Larry. |
07-05-2008, 11:34 | #4469 (permalink) | |
Member: 571038 Status: Offline Thanks Meter: 40 | Quote:
07-05-2008, 14:00 | #4470 (permalink) | |
Member: 351332 Status: Offline Thanks Meter: 0 | Quote:
Thank you | |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
