Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
12-17-2005, 10:01 | #61 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: PHIL
Member: 197247 Status: Offline Thanks Meter: 296 | Quote:
12-17-2005, 18:32 | #62 (permalink) |
Registered User Join Date: Jun 2004 Age: 46
Member: 68983 Status: Offline Thanks Meter: 55 | 1st Boot Ok, TIKU, UPP: 1052 Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ET Fl1: 0x02000000-0x02FFFFFF,00EC0020,Sam NOR 16 Mb Algorithm: te_oncsm.fia Erasing Mass Memory Erasing Error: Bad MM PartitionMM_2D_1, Time: 00:56 Process Failed, Repowering Mobile this my problem for nokia 7280 thank you |
12-17-2005, 18:45 | #63 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 198756 Status: Offline Thanks Meter: 59 | nokia 3220 restarted and white screen hello dear s i have 3x nokia 3220 whith problems : 1 two of thenm are restarted after powering on 2 the last one has a white screen hints:nokia 3220 the new virsion on the market 4.94 and 5.10 |
12-17-2005, 20:33 | #64 (permalink) |
No Life Poster Join Date: Oct 2005 Location: T.E.T.O.U.A.N
Member: 190492 Status: Offline Sonork: 100.01010100 Thanks Meter: 190 | 3410 with ufs3 i have one 3410 ..it's be ok when i attached it with ufs means power but when i turn on with battery still off i change switch on/off but still same means OFF i flash it it's be on just in ufscableprogram any solution am sur in hardware good luck for all |
12-17-2005, 21:05 | #66 (permalink) |
Junior Member Join Date: Dec 2005
Member: 204855 Status: Offline Thanks Meter: 0 | Request help for N6600 (curious problem) hello everyone! i am facing a problem with my nokia 6600 phone, this problem is common to many holders of this phone in my country here... and effectively there is no solution... the phone start having errors with bluetooth not openin (system error is reported or app btui.exe is closed due to an error)... after that the gallery doesn't open anymore, the browser cannot connect to the internet, camera can't take pictures (temporary overload is reported) other different errors are reported all the time of terminated application (screensaver.exe app closed... and others) the most curious also is that when i turn the phone on and off many times (sometimes it takes 5-70 times) it get to work again... but when i turn it off again the same problems rehappen... the more curious is that i have already taken my phone to the nokia service center 2 times in one month... they flash the firmware, test everything, charge u... and the phone is repaired... but after one week of working perfectly, the phone is buggy again... though the technicians at nokia always say that it is a software problem and that the hardware is working perfectly... i am starting to get tired from this... i have tried formating the phone and freeing memory and these details... plus i have already flashed my phone 2 times (and it's not efficient and ain't a permanent solution... plus it's very expensive 30$ per flash) maybe it's due to a particular application i install on my phone... i dunno... but has anybody got a clue? could anyone help plz? i would appreciate any suggestion... Sincerly, |
12-17-2005, 21:59 | #67 (permalink) |
Member: 190492 Status: Offline Sonork: 100.01010100 Thanks Meter: 190 | now it's okis i find a solution i attached betwen power switch and Resitance ...i do it with color Blue in Picture good luck friends |
The Following User Says Thank You to Tetouan Gsm For This Useful Post: |
12-17-2005, 22:05 | #68 (permalink) | |
Member: 190492 Status: Offline Sonork: 100.01010100 Thanks Meter: 190 | virus..? Quote:
12-18-2005, 16:13 | #69 (permalink) |
Insane Poster Join Date: Dec 2005 Location: UAE-IND Age: 45
Member: 208901 Status: Offline Thanks Meter: 1 | Nokia 3220 while boot 4 side color lights unable to glow i have nokia 3220 the phone is working fine just there is a problems with 4 side colors Light those lights are unable to light anymore while booting even if we recevied a call then it must glow but its not glowing anymore i did Flash, plz do needful help for me, Thanks lot for all Seriors who always help on this website hope they wil give me some good ideas. Best Regards AR |
12-18-2005, 17:37 | #70 (permalink) |
Member: 207689 Status: Offline Thanks Meter: 1 | I am sorry for disturbing you. I am a mobile phone amateur in P.R.China. My own 7610 can't charge after I charged it with an ACP-7 charger. I have checked the schematic of 7610, all the way form charger pin the the UEME chip pin are: one fuse F130, a reactor, a diode and severa capacitors. There is no response when I plug in the cahrger....sigh. I think the UEME chip is broken. I want to change it. Is this process very risky? And what things should I pay attention to. My friends got a griffin flasher. Is it enough? If there is some programs that I dont have.....can you send or post them to me, if they are not very large.....I am really a rookie and ned some help. Buddy, thanx!!!!! my email: [email protected] |
12-19-2005, 10:12 | #74 (permalink) |
No Life Poster Join Date: Feb 2003 Location: somewhere
Member: 23372 Status: Offline Thanks Meter: 18 | have problem with my 7610 the phone is normaly on but after a few minutes the lcd suddenly disappeared and if i turn it off and on it again the lcd revive again after a whinle again it gone again need help |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
