Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
05-20-2014, 14:09 | #8810 (permalink) |
Junior Member Join Date: Mar 2014 Location: Islamabad, Pakistan
Member: 2158787 Status: Offline Thanks Meter: 0 | - > No any CRT data (MCU damaged/CERT erased), skip saving anyone can tell me that if you get the above message on infinity best, then what does it mean |
05-20-2014, 15:03 | #8811 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1454715 Status: Offline Thanks Meter: 0 | ufs micro CPU: AuthenticAMD Platform: Windows NT 5.1 (Build 2600 Service Pack 3) Versions: Ufs2xx.dll 3.1.19, Ufs2xx.sys 2.6.0 C:\Program Files C:\Program Files\Common Files Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix C:\Documents and Settings\ALIYA MOBILE\Desktop C:\Documents and Settings\ALIYA MOBILE\Start Menu\Programs Box: 1 Location: 49 Serial: 75615 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 75615 HID: E8AF36524360005B, HWK: A1.04-PRO1 BOX_AUTH_ERROR: 20 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Your IP: 83.110.206.205 Support: Account Ok Something Wrong, Try to Use [Update Box] Box: 1 Location: 49 Serial: 75615 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 75615 HID: E8AF36524360005B, HWK: A1.04-PRO1 BOX_AUTH_ERROR: 20 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Your IP: 83.110.206.205 Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 75615 NVML: OK INIT FBI Failed ! Box: 1 Location: 49 Serial: 75615 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 75615 HID: E8AF36524360005B, HWK: A1.04-PRO1 BOX_AUTH_ERROR: 20 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Your IP: 83.110.206.205 Support: Account Ok Something Wrong, Try to Use [Update Box] Last Server Update: 20013/08/21 Not Active Anymore ! For new use this link: Sarunasoftware Support Area -> Message from system No New Items to Install No Items from Server Use [Check Server] Last Server Update: 20013/08/21 Not Active Anymore ! For new use this link: Sarunasoftware Support Area -> Message from system No New Items to Install |
07-02-2014, 05:03 | #8819 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2215148 Status: Offline Thanks Meter: 0 | Nokia N95-3 RM-160 I all, I am having a big problem trying to reset without success. I`ve tried the three keys "* + 3 + send" , I also tried to connect to nokia pc suite no success. The phone is keeping asking for the lock code after the turning on. I typed 12345 code. What can I do next ?? the phone is not responding to anything but the code. Can anyone explain me what is happening? Thanks in advance. |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
