Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 12-20-2005, 14:25   #76 (permalink)
Member: 210923
Red face
pls my 6230 heats up and the battery runs low when its on.o i dont have to charge it before it gets hot helpppppppppppppp
Old 12-20-2005, 20:53   #77 (permalink)
Member: 79443
Thanks Meter: 11
i have a problem with nokia 2100, the phone is always showing low batery and trips off even if its a new batery is will still show low betry and goes off
Old 12-21-2005, 07:55   #78 (permalink)
adomshima's Avatar
Member: 78679
Thanks Meter: 3
my 6020 not powering ON and the back ligth not showing,any idea? thanks.
Old 12-21-2005, 08:12   #79 (permalink)
Member: 211167
I need usb driver 4 moto c380 ? can u help me?
Old 12-21-2005, 10:55   #80 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
hi friends this is the first that I see on 6230. I have never seen that problem yet, the phone working well but when clock screen saver apear the phone is turning off. I flashed many times, factory setting notthing helped! Any idea!? Please help!
Regards.
Old 12-22-2005, 04:21   #81 (permalink)
Crazy Poster
Member: 183379
Thanks Meter: 10
hi mates, im confuse with some network problems ..example(1) nokia 3310 power on after 5 sec (no network) but when i open keylock making a call n the line was coming out again.( i hv change PA,HAGAR,CCONT)..example(2)nokia 8250 after change (PA,HAGAR,CCONT)after power on it got network but faling when i try msging or sending msg..it say no network coverates... sorry for my broken english n pls try help me !! thanks
Old 12-22-2005, 05:38   #82 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
check the pa men if not check uem
Old 12-22-2005, 05:39   #83 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
check cnnt cobba and PA also keypad ic
Old 12-22-2005, 05:40   #84 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
do you have jaf flasher?? you need to full flash
Old 12-22-2005, 05:41   #85 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
Regards.
new one in deed try to check flash ic reheat or change
Old 12-22-2005, 05:42   #86 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
you did skip changing audio ic right or cobba
Old 12-22-2005, 05:44   #87 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
Originally Posted by greeni222000
hello dear s
i have 3x nokia 3220 whith problems :
1 two of thenm are restarted after powering on
2 the last one has a white screen
hints:nokia 3220 the new virsion on the market 4.94 and 5.10
did you flash it with same version???
Old 12-22-2005, 05:48   #88 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
Originally Posted by jln310
have problem with my 7610 the phone is normaly on but after a few minutes the lcd suddenly disappeared and if i turn it off and on it again the lcd revive again after a whinle again it gone again need help
change lcd did you try?? or resolder its connector
Old 12-22-2005, 05:49   #89 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
Originally Posted by snipergsm
1st Boot Ok, TIKU, UPP: 1052
Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ET
Fl1: 0x02000000-0x02FFFFFF,00EC0020,Sam NOR 16 Mb
Algorithm: te_oncsm.fia
Erasing Mass Memory
Erasing Error: Bad MM PartitionMM_2D_1, Time: 00:56
Process Failed, Repowering Mobile
this my problem for nokia 7280
thank you
i think its not the flash file try reheating flash ic
Old 12-22-2005, 05:53   #90 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
Originally Posted by hammadsheikh
i just want to make unlimited movie in N-6230..is it possible if yes so how????
mmmm dosent seem to work but ask java john about this one
post me your problem in motorola and let me give you the rite solution greeni222000 Motorola Hardware Repair 2127 03-19-2018 15:17
Post me your BB5 problem here.. Ill try to help with Pict ichal_spy Nokia Hardware & Hardware Repair 13 10-05-2014 09:23
!!!!post Me Your Hardware Problem!!!! Ustad rajab.Com Nokia Hardware & Hardware Repair 32 01-18-2013 07:37
post me your all 6600 problem tommobil2005 Nokia Repair Guide and FAQ 459 01-17-2011 11:23
Page generated in 0.42301 seconds with 9 queries
