Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 12-22-2005, 07:53   #91 (permalink)
Crazy Poster
Member: 183379
Thanks Meter: 10
yes i try change cobba oredi after u told me but nothings change..now i hv change ( pa,antena switch,ccont,hagar n cobba) also flash with knock95...
Old 12-22-2005, 08:21   #92 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
nokia 6230 white display
your help ...... 1. you must have flash and erase your software.
2.if you save ,it you can retieve it into your mobile.
3. you need to download , your mobile flash files.
4.there are websites for this.
i am waiting ....
bestman
Old 12-22-2005, 09:40   #93 (permalink)
Member: 175494
Hi Bro,
I am facing a problem with my cell, actually i forgot the som lock code of my cell and now i cant tuurn on my cell. whwnever i turn on my cell it asked for the code that i forgot, can you help me out please, ASAP.
Thanx
Frozenfire
Old 12-22-2005, 09:41   #94 (permalink)
Member: 175494
Hi Bro,
I am facing a problem with my cell, actually i forgot the sim card lock code of my cell and now i cant tuurn on my cell. whwnever i turn on my cell it asked for the code that i forgot, can you help me out please, ASAP.
Thanx
Frozenfire
Old 12-22-2005, 09:54   #95 (permalink)
Member: 211598
hiya i dont now if you can help me but am really in need of help. My new sony w550i phone has broken. The screen is just white and wondered what the hell i can do to fix it. Rang sony and they said basically that the phone was buggered.just basically want to know if thois true or is there some small chnace it can be fixed???
Old 12-22-2005, 10:07   #96 (permalink)
N.I.T's Avatar
Member: 204243
Thanks Meter: 67
Originally Posted by abel peter
i have a problem with nokia 2100, the phone is always showing low batery and trips off even if its a new batery is will still show low betry and goes off
change its p.f or power i.c
Old 12-22-2005, 10:11   #97 (permalink)
N.I.T's Avatar
Member: 204243
Thanks Meter: 67
Originally Posted by gkaraan
hello everyone!
i am facing a problem with my nokia 6600 phone, this problem is common to many holders of this phone in my country here... and effectively there is no solution...
the phone start having errors with bluetooth not openin (system error is reported or app btui.exe is closed due to an error)... after that the gallery doesn't open anymore, the browser cannot connect to the internet, camera can't take pictures (temporary overload is reported)
other different errors are reported all the time of terminated application (screensaver.exe app closed... and others)
the most curious also is that when i turn the phone on and off many times (sometimes it takes 5-70 times) it get to work again... but when i turn it off again the same problems rehappen...
the more curious is that i have already taken my phone to the nokia service center 2 times in one month... they flash the firmware, test everything, charge u... and the phone is repaired...
but after one week of working perfectly, the phone is buggy again...
though the technicians at nokia always say that it is a software problem and that the hardware is working perfectly...
i am starting to get tired from this...
i have tried formating the phone and freeing memory and these details...
plus i have already flashed my phone 2 times (and it's not efficient and ain't a permanent solution... plus it's very expensive 30$ per flash)
maybe it's due to a particular application i install on my phone... i dunno...
but has anybody got a clue? could anyone help plz?
i would appreciate any suggestion...
Sincerly,
change its bt module and after this format phone
Old 12-22-2005, 20:57   #98 (permalink)
Member: 79443
Thanks Meter: 11
my x100 is hanging pls help to solve this problem
Old 12-23-2005, 01:53   #99 (permalink)
bauzito's Avatar
Member: 120120
Sonork: 100.1592092
Thanks Meter: 234
how about nokia 1600 insert sim after 30 minutes????????????????
Old 12-23-2005, 02:22   #100 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
try replacing voltage control oscillator or VCO in it is the same reheat flash ic i think this maybe our last resort good luck
Old 12-23-2005, 02:24   #101 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
Originally Posted by frozenfire
Hi Bro,
Thanx
Frozenfire
post me the imei of your phone and ill give you master code
Old 12-23-2005, 02:27   #102 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
did you dropped it or some thing?? this things always happen maybe you load so many apps try flashing it do you have setools??? or cruiser
Old 12-23-2005, 02:29   #103 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
format or flashing this should do it
Old 12-23-2005, 02:29   #104 (permalink)
Member: 209176
Originally Posted by nolyboy
what do you mean ph?? try to put pm file
ph=philippines...im a newbie dont know anything about cellpfone troubleshooting, but willing to learn...thanks for any help/info you can provide..
Old 12-23-2005, 02:30   #105 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
did you check sim ways?? can you post a screen shot of it??
post me your problem in motorola and let me give you the rite solution greeni222000 Motorola Hardware Repair 2161 12-25-2023 05:54
Post me your BB5 problem here.. Ill try to help with Pict Rizal Arsyad Dini Nokia Hardware & Hardware Repair 13 10-05-2014 09:23
!!!!post Me Your Hardware Problem!!!! Ustad rajab.Com Nokia Hardware & Hardware Repair 32 01-18-2013 08:37
post me your all 6600 problem tommobil2005 Nokia Repair Guide and FAQ 459 01-17-2011 12:23
Page generated in 0.28636 seconds with 10 queries
