Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 06-28-2006, 14:29   #1 (permalink)
Member: 302074
Smile Post us your problems
hello friends we are here to solve all problems of yours . post all your probs here
xxxxxxxxxxx
post your phone number again and you will be banned forever
The Following 2 Users Say Thank You to al-wahab-team For This Useful Post:
Old 06-28-2006, 14:42   #2 (permalink)
Member: 293868
Sir ,
i have a porblem 6100 flashed and it is dead no first boot ok but at mass memory erasing not done
The Following User Says Thank You to mohsin_akhtar For This Useful Post:
Old 06-28-2006, 14:47   #3 (permalink)
Member: 302074
Originally Posted by mohsin_akhtar
Sir ,
dear, give some heat to falsh IC and then falsh it with new version
Old 06-28-2006, 14:50   #4 (permalink)
Member: 293868
thanx wahab team you are very help full
Old 06-29-2006, 08:09   #5 (permalink)
sygnal's Avatar
Member: 235471
got 6600 START UP FAILED CONTACT RETAILER i already flasf the phone UEM serial in good change the bt module but still the same.
Old 06-29-2006, 08:45   #6 (permalink)
Crazy Poster
Member: 246952
Problem with nokia 3220
salaam,
dear brother,
i am getting problem with NOKIA3220, Keypad is not working perfectly,
some buttons are working good, but some arent.
please help me.
Old 06-29-2006, 08:55   #7 (permalink)
mohamedsafi123's Avatar
Member: 170244
salaam friend
farmet ur set press *=3+green button+on/off switch u see in display " farmetting" after farmet all fault is solved ..................
Old 06-29-2006, 10:05   #8 (permalink)
Member: 290268
i have got nokia 6030 & its software has got corrupted i have decided to get it right from nokia service centre but in future is there any solution for this so that I can upload the software myself ? plz guide me as i am very intrested in these type of R&D works
Old 06-29-2006, 11:20   #9 (permalink)
Member: 187731
7260 camera
When I try to open camera, it gives me "operation failed". I know that there is similar solution for 7250 by jumpering two points over the camera IC, but with 7260 ??? Please help!
Old 06-29-2006, 11:37   #10 (permalink)
Member: 302376
Oldie for y'all.
Replaced cog wheel and ribbon on my beloved 8910 BUT now the slider is no longer 'active' i.e doesn't end calls when you close it and so on.
My 8850 has been much repaired over the years (still in good service) and I can see the microswitch on the bottom of the board, but I'm scratching my head over how the 8910 knows its open or closed !
Any help would be appreciated.
Cheers
Old 06-29-2006, 14:03   #11 (permalink)
Member: 302741
greetz! i have a problem a nokia 3650, the phone is simply dead. When i press the power button the display is still black. I tried to switch the battery with other one, but still no sign. I can't figure it out... what should i do? any ideeas ?
Old 06-29-2006, 17:54   #12 (permalink)
Moderator
..::ArchitRaj::..'s Avatar
Member: 181696
Sonork: 100.107830
Originally Posted by vasim22281
salaam,
dear brother,
please help me.
rebaalll or change keypad ic
Old 06-29-2006, 18:06   #13 (permalink)
Member: 240930
Hi guys,
I have a 6670 Nokia and that lcd was blank screen,
I change lcd but not respond then ic lcd and socket
changed but not answered ,This flash complete by
last version but lcd is white then i changed CPU
and Sram,not answerd to now,
My ufs box preview this message:
1st Boot Ok, WD2, UPP: 1081
2nd Boot Error: 6
Platform: 6, Error Data:
F3 72 72 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Process Failed, Repowering Mobile
Any solution,please?Thanks
Old 06-29-2006, 18:44   #14 (permalink)
Member: 302838
solution
flash the fone with a twister
Old 06-29-2006, 18:58   #15 (permalink)
Member: 302838
flash the fone with a twister or jaff or tornado. it works for me as long it booth ok on the system
post me your problem nolyboy Nokia Repair Guide and FAQ 8852 05-19-2013 12:15
post me your problem in motorola and let me give you the rite solution greeni222000 Motorola Hardware Repair Section 2047 03-02-2013 11:57
Post us your problems al-wahab-team Nokia Hardware & Hardware-Repair Area 1 06-28-2006 15:13
Page generated in 0.35072 seconds with 12 queries
