Solution Of Reconnect Charger or Charge By Itself. For 3310 4 Attachment(s) Solution for 3310 reconnect charger or charge by itself : 1 : In the first picture you see the via hole that in most cases cause this kind of fault. It's cut/disconnected and will therefore have a open line and have problems wth either charging or selfcharging. 2 : Mount a thin wire as in picture 2 through the via hole. 3 : Cut the wire on both sides of PCB. 4 : Solder the wire on both sides of the PCB to connecting lines. Now you should have a working phone that charges correctly, or does not selfcharge. Br Keany **Proofread and edit of text. Added as sticky thread to hardware repair series by GSM Coolhawk** |
@keany Good work... I've proof read the text and changed where nessesary. Furthermore I've added this post to the "Hardware Repair Series" as a sticky thread in the index here so these kind of faults and their solution can be easily found. Regards |
Simple trick to solve 3310 continuous charging 1 Attachment(s) A broken pattern from R22o going to the vbb_main results in self charging. The quick way to solve this is by bridging it. The nearest part happens to be c200 going to vbb. The holes on the pcb-keypad serves the purpose........ just another option :) |
@ nuj good explanation! :) keep up the good work. u wouldn't say that u r a junior member :) |
on the phone PCB there is an interrupted way (somwhere on the right part of PCB - keybord side). It is a very very thin way, and it starts from + connector |
@keany & nuj i have 5 problems reconnect charger 33xx 4 of them succesfull thanks |
******* Please keep within the topic, this is 3310 not charging. For other models, please start a new thread. Thanks |
you can try this application above . bestman. |
thanks for the posts ... verry useful ! regards ! |
very good indeed very very usefull continew |
thank you its ok :p good work |
...........................thanks................. .............. |
Thaaaaanx. I will try it. Fantastic work |
i have a nokia 3320 its ringer point from pcb is dicinect any body can tell me the shortcut point for ringer thanx in advanc |
thanks good work |
