Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 07-16-2004, 08:39   #1 (permalink)
keany's Avatar
Member: 67419
Thumbs up Solution Of Reconnect Charger or Charge By Itself. For 3310
Solution for 3310 reconnect charger or charge by itself :
1 : In the first picture you see the via hole that in most cases cause this kind of fault. It's cut/disconnected and will therefore have a open line and have problems wth either charging or selfcharging.
2 : Mount a thin wire as in picture 2 through the via hole.
3 : Cut the wire on both sides of PCB.
4 : Solder the wire on both sides of the PCB to connecting lines.
Now you should have a working phone that charges correctly, or does not selfcharge.
Br Keany
**Proofread and edit of text. Added as sticky thread to hardware repair series by GSM Coolhawk**
The Following 11 Users Say Thank You to keany For This Useful Post:
Old 07-16-2004, 11:43   #2 (permalink)
GSM Coolhawk's Avatar
Member: 7751
@keany
Good work...
I've proof read the text and changed where nessesary. Furthermore I've added this post to the "Hardware Repair Series" as a sticky thread in the index here so these kind of faults and their solution can be easily found.
Regards
Old 07-16-2004, 19:06   #3 (permalink)
nuj
Member: 72392
Simple trick to solve 3310 continuous charging
A broken pattern from R22o going to the vbb_main results in self charging. The quick way to solve this is by bridging it. The nearest part happens to be c200 going to vbb. The holes on the pcb-keypad serves the purpose........
just another option
File Type: jpg NOKIA_3310 continuous charging solution.jpg (30.2 KB, 7783 views)
The Following 3 Users Say Thank You to nuj For This Useful Post:
Old 07-16-2004, 20:05   #4 (permalink)
Member: 8843
@ nuj
good explanation! keep up the good work. u wouldn't say that u r a junior member
Old 07-16-2004, 22:52   #5 (permalink)
Member: 73571
on the phone PCB there is an interrupted way (somwhere on the right part of PCB - keybord side). It is a very very thin way, and it starts from + connector
Old 07-19-2004, 00:08   #6 (permalink)
Unggul's Avatar
Member: 71273
@keany & nuj
i have 5 problems reconnect charger 33xx 4 of them succesfull thanks
Old 07-20-2004, 15:29   #7 (permalink)
Member: 10243
Please keep within the topic, this is 3310 not charging. For other models, please start a new thread. Thanks
The Following User Says Thank You to bedjo For This Useful Post:
Old 07-25-2004, 01:29   #8 (permalink)
bestman's Avatar
Member: 61294
you can try this application above .
bestman.
Old 07-26-2004, 21:41   #9 (permalink)
goanga's Avatar
Member: 57035
thanks for the posts ... verry useful ! regards !
Old 08-08-2004, 06:04   #10 (permalink)
Member: 73144
very good indeed very very usefull continew
Old 08-14-2004, 02:44   #11 (permalink)
Registered User
Member: 77237
thank you its ok good work
Old 08-15-2004, 06:33   #12 (permalink)
TechPhone's Avatar
Member: 41672
...........................thanks................. ..............
Old 08-16-2004, 18:23   #13 (permalink)
DineshDias's Avatar
Member: 77943
Thaaaaanx. I will try it. Fantastic work
The Following User Says Thank You to DineshDias For This Useful Post:
Old 08-24-2004, 14:40   #14 (permalink)
nobal1976's Avatar
Member: 71190
Sonork: 100.1580485
i have a nokia 3320 its ringer point from pcb is dicinect any body can tell me the shortcut point for ringer
thanx in advanc
Old 08-26-2004, 02:33   #15 (permalink)
hanen's Avatar
Member: 70053
thanks
good work
DCT-4 & BB5 Charger or Charging Not Supported Solution BY SONU gsm junction Nokia Hardware & Hardware-Repair Area 33 03-13-2010 16:08
DCT-4 & BB5 Charger or Charging Not Supported Solution kashi4gul Nokia Hardware & Hardware-Repair Area 27 12-03-2008 07:20
3100 shows not charging by itself without charger hooi76 Nokia Hardware & Hardware-Repair Area 10 06-27-2007 02:06
HELP Solution for 1100 reconnect charger or charge by itself ? sapatos Nokia Hardware & Hardware-Repair Area 2 08-27-2005 10:33
charging by itself Lutfe Samsung Hardware Repair Area 10 06-07-2004 23:56
Page generated in 3.64367 seconds with 12 queries
