Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
01-01-2010, 19:12 | #3951 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Srilanka
Member: 943193 Status: Offline Thanks Meter: 3 | Sir, Can u explain me, how to flash BB5 with jaf , step by step?? then, what is that RPL ? Some BB5 models have contact Service problem please explain me how to repair that contact Service, then where can i find that rpl file ? how to repair that BB5 contact service ( rpl ) problem with jaf, Can anybody explain me by step by step,, or by picture ***** will help u for All |
01-01-2010, 19:13 | #3952 (permalink) | |
Freak Poster Join Date: Feb 2009 Location: Indonesia Age: 41
Member: 975117 Status: Offline Sonork: rivacomcell center Thanks Meter: 45 | Quote:
1. PLEASE CHECK LINE vbatt FOR L2304 TO CONNECTOR BATRE + IF NOT JUMPER THIS LINE. 2. REPLACE/CHANGE V2300. 3. CHANGE BETTY IC DONT FORGET TO SAY THANKS WITH ME.GOOD LUCK BRO | |
01-01-2010, 19:23 | #3953 (permalink) | |
1. Check line vbat l2401 to connector batre + if not oke jumper it 2. Check line led connector keypad. 3. Change keypad connector if bad. 4. Change led ic (n2400). Try it bro..post reply again with me to result if oke and done please dont forget to say thanks with me..good luck bro | |
01-01-2010, 19:31 | #3954 (permalink) |
Member: 943193 Status: Offline Thanks Meter: 3 | Sir, can u explain me ,how to flash bb5 models by jaf please explain by picture?? then what is that rpl problem ,,bb5 some models having that contact service problem(rpl missing), why coming that rpl problem, If appeared that problem how to solve by jaf??? please then where can i find that rpl file?? then i have 2 mobile 5130xp , 5310xp contact sevice problem ,when i power on that mobiles nokia appearing then contact service appearing, please please help |
01-02-2010, 01:54 | #3955 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1020509 Status: Offline Thanks Meter: 5 | nokia 5310 open nokia and then nothing after flash in jaf the problem not change after flash write failed aborting..! with more cables by 10.10 version i wont final solution for this problem |
01-02-2010, 04:29 | #3956 (permalink) |
Junior Member Join Date: Mar 2008 Location: TAMILNADU
Member: 731784 Status: Offline Thanks Meter: 1 | sony j6 ringer and charging hi, i have a sony j6 . the strip connecting the ringer, control and lock is damaged. i have fixed for speaker and mike , they are working fine. The ringer is not working. i have tracked the line from that connector to the ringer, still does not work. please could you help me with a picture where do i make a jumper on the board so that the ringer works. sony j6 does not charge but powers on. please could you help me with a picture what to be done. thanks in advance |
01-02-2010, 13:59 | #3958 (permalink) |
Junior Member Join Date: Dec 2008
Member: 935579 Status: Offline Thanks Meter: 0 | on my n95 there is no sound when calling out, not even ringing tone. i checked jumpers and speaker it contacts well, they hear me and i don't. i replaced speaker it didn't help. sometimes i cleaned the speaker and it worked for few days but now it doesn't at all. thanks in advance |
Solving Your CDMA Problem Within 24 hours | kapil2007chakde | Various CDMA/TDMA Cell Phones | 770 | 04-20-2017 22:20 |
..::solve Your Problem Within 24 Hours::.. | RIZWANJAT | Nokia Hardware & Hardware Repair | 16 | 02-03-2013 08:50 |
