Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
01-04-2010, 08:21 | #3977 (permalink) | |
Junior Member Join Date: May 2007
Member: 500983 Status: Offline Thanks Meter: 0 | Quote:
hai MR Pupaji,regarding my problem N96,which cable need to check.. | |
01-04-2010, 08:24 | #3978 (permalink) |
Junior Member Join Date: Jun 2005 Age: 39
Member: 150014 Status: Offline Thanks Meter: 0 | N95 31.0.015 - Need Crack Plz. help me to hack/crack the Nokia N95 31.0.015 firmware, Iam not able to install the applications and games in my mobile.....plz. help me ,,i tried many tricks but all in vain.... My maild Id: [email protected] my IMEI no. 359542017983600 |
01-04-2010, 11:53 | #3980 (permalink) |
Major Poster Join Date: Feb 2009
Member: 965499 Status: Offline Thanks Meter: 3 | hi, my nokia n95 was broken into 2 pieces the lcd strip was broken. I've replaced the strip/cable 1st time it worked fine after few days when i turned it on, it boots up but then lcd goes off and it restarts. cud u please help me what shud i do. I've rechecked the connector n cleaned them as well but no luck........ thanks in advance.... |
01-04-2010, 11:57 | #3981 (permalink) |
01-04-2010, 19:45 | #3982 (permalink) |
Junior Member Join Date: Mar 2007
Member: 460522 Status: Offline Thanks Meter: 2 | my nokia 6670 keypad numbers one after the other stop working. now few keys are working can you please give me a solution for this. I changed from a working phone keypad board to this phone and same . also I replace this phone keypad board with another working phone and it works. So this means it’s a problem with motherboard. can you please help |
01-05-2010, 11:51 | #3984 (permalink) |
Freak Poster Join Date: May 2008
Member: 779022 Status: Offline Thanks Meter: 20 | Need help with N95-3 RM160 start OK working then switch of after 2 to 5 minutes! Please give solution for this problem with this problem diagram if possible. Thanks in advance. |
01-05-2010, 13:36 | #3985 (permalink) | |
Freak Poster Join Date: Oct 2007 Location: INDIA
Member: 605575 Status: Offline Sonork: 100.1597056 Thanks Meter: 20 | Quote:
reball rap cpu ic.......proparly..... | |
01-05-2010, 15:51 | #3987 (permalink) |
No Life Poster Join Date: Apr 2009 Location: MobiCare, Mh-50, India
Member: 1019814 Status: Offline Thanks Meter: 653 | http://forum.gsmhosting.com/vbb/showthread.php?t=894516 I'm too confused.. |
01-05-2010, 16:07 | #3988 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1201245 Status: Offline Sonork: 10011 Thanks Meter: 0 | Do you have a weight loss goal? a financial goal? a parenting goal? a team goal? any kind of goal? Goal Patrol is a patent pending motivational bracelet system for goal setting and goal getting. This motivational system breaks your goal down into five baby steps. Each of the five bracelets included in your kit corresponds to one step towards your goal. Change your goal bracelet after each step you complete, and before you know it, you'll conquer your goal. This goal setting sytem is a unique method for achieving your personal goals and team goals. Set goals and achieve goals with this fun motivational product! goal setting |
01-05-2010, 16:53 | #3989 (permalink) |
Member: 1200447 Status: Offline Thanks Meter: 0 | Hi, Could you please tell me how to assemble a nokia n76. I have dismantled the phone to put a new faceplate on, but there is a wire that I am hesitant to touch. I have checked out previous links and searched on the internet everywhere but all links are broken. The wire holds both faceplates and runs through the flip's wheel so there is no way I can put the new faceplate on without removing it. Arrgghhh sorry I don't know the actual name of the wire or the technical talk. I think I have totalled my phone!! I hope you can help, please let me know if you need any further info. |
Solving Your CDMA Problem Within 24 hours | kapil2007chakde | Various CDMA/TDMA Cell Phones | 770 | 04-20-2017 22:20 |
..::solve Your Problem Within 24 Hours::.. | RIZWANJAT | Nokia Hardware & Hardware Repair | 16 | 02-03-2013 08:50 |
