Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 01-04-2010, 01:30   #3976 (permalink)
Member: 1020509
Thanks Meter: 5
Originally Posted by m.malik View Post
nokia 5310 open nokia log and then nothing
after flash in jaf the problem not change
after flash write failed aborting..!
with more cables by 10.10 version
i wont final solution for this problem
any budy say any thing about my problem ....pupa... where r u
Old 01-04-2010, 08:21   #3977 (permalink)
Member: 500983
Originally Posted by pupaji View Post
did you check the cable?
Originally Posted by zaidenz View Post
hello,I have problem with my N96,after change Lcd..battery drain faster, after 1 hour charging and whole body comes hot and now cant turn on.what is the problem,need help.
hai MR Pupaji,regarding my problem N96,which cable need to check..
Old 01-04-2010, 08:24   #3978 (permalink)
Member: 150014
N95 31.0.015 - Need Crack
Plz. help me to hack/crack the Nokia N95 31.0.015 firmware, Iam not able to install the applications and games in my mobile.....plz. help me ,,i tried many tricks but all in vain....
My maild Id: [email protected]
my IMEI no. 359542017983600
Old 01-04-2010, 10:49   #3979 (permalink)
Member: 779022
Thanks Meter: 20
what you finished with it?
i think this rpl problem
Please show me how to fix this problem with junper
Thank you
Old 01-04-2010, 11:53   #3980 (permalink)
Member: 965499
Thanks Meter: 3
hi, my nokia n95 was broken into 2 pieces the lcd strip was broken. I've replaced the strip/cable 1st time it worked fine after few days when i turned it on, it boots up but then lcd goes off and it restarts. cud u please help me what shud i do. I've rechecked the connector n cleaned them as well but no luck........
thanks in advance....
Old 01-04-2010, 11:57   #3981 (permalink)
Member: 965499
Thanks Meter: 3
Old 01-04-2010, 19:45   #3982 (permalink)
Member: 460522
Thanks Meter: 2
my nokia 6670 keypad numbers one after the other stop working.
now few keys are working can you please give me a solution for this.
I changed from a working phone keypad board to this phone and same .
also I replace this phone keypad board with another working phone and it works.
So this means it’s a problem with motherboard.
can you please help
Old 01-04-2010, 19:47   #3983 (permalink)
Member: 460522
Thanks Meter: 2
what is "rehot cpu nokia 2630"?
I dnt know how to do rehot.
please explain
Old 01-05-2010, 11:51   #3984 (permalink)
Member: 779022
Thanks Meter: 20
Need help with N95-3 RM160 start OK working then switch of after 2 to 5 minutes!
Please give solution for this problem with this problem diagram if possible.
Thanks in advance.
Old 01-05-2010, 13:36   #3985 (permalink)
Member: 605575
Sonork: 100.1597056
Thanks Meter: 20
Originally Posted by gsmshare View Post
mr pupaji please solved this:
N70 can't on,,,
cmt boot data:
Asic id: 000000010000022600010006000c192101002200
asic mode id: 00
asic em id: 00000352
asic public id: 0eb0001087c34f51ce8e43fbcfffbbc5e6bb6a4c
hash: E9eff4bfaa5393217ca6b17755fc3e1400000000
rom id: F28a211fcea7b19d
cmt boot file: C:\program files\odeon\jaf\flash\rap3gv2_2nd.fg
loader version: 01.15.00 -> revision: 0000
patching cmt boot step2...
Cmt boot ready
cmt flash id: 73656c69 <=> flash id not in database
cmt flash data: 5c4e6f6b69615c50686f656e69785c50
error finding cmd loader...
I wait for your solution,,,,
reball rap cpu ic.......proparly.....
Old 01-05-2010, 15:17   #3986 (permalink)
Member: 1201145
i have a nokia n91 menu key will not work anyway it can be repaird thanks
Old 01-05-2010, 15:51   #3987 (permalink)
k_abhi's Avatar
Member: 1019814
Thanks Meter: 653
http://forum.gsmhosting.com/vbb/showthread.php?t=894516 I'm too confused..
Old 01-05-2010, 16:07   #3988 (permalink)
Member: 1201245
Sonork: 10011
Do you have a weight loss goal? a financial goal? a parenting goal? a team goal? any kind of goal? Goal Patrol is a patent pending motivational bracelet system for goal setting and goal getting. This motivational system breaks your goal down into five baby steps. Each of the five bracelets included in your kit corresponds to one step towards your goal. Change your goal bracelet after each step you complete, and before you know it, you'll conquer your goal. This goal setting sytem is a unique method for achieving your personal goals and team goals. Set goals and achieve goals with this fun motivational product!
goal setting
Old 01-05-2010, 16:53   #3989 (permalink)
Member: 1200447
Hi,
Could you please tell me how to assemble a nokia n76. I have dismantled the phone to put a new faceplate on, but there is a wire that I am hesitant to touch. I have checked out previous links and searched on the internet everywhere but all links are broken. The wire holds both faceplates and runs through the flip's wheel so there is no way I can put the new faceplate on without removing it. Arrgghhh sorry I don't know the actual name of the wire or the technical talk. I think I have totalled my phone!! I hope you can help, please let me know if you need any further info.
Old 01-05-2010, 19:28   #3990 (permalink)
Member: 1183590
Red face 6116 nokia
Respected friends....
post your problems here.........I will try to solve that by pic within 24 hours.......
best reguards....
dear my nokia 6116 some times before showing whit lcd, i have removed lcd but mobile is not starts now. plz help
Solving Your CDMA Problem Within 24 hours kapil2007chakde Various CDMA/TDMA Cell Phones 770 04-20-2017 22:20
..::solve Your Problem Within 24 Hours::.. RIZWANJAT Nokia Hardware & Hardware Repair 16 02-03-2013 08:50
Page generated in 0.23866 seconds with 10 queries
