Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
09-05-2009, 15:20 | #3001 (permalink) |
Insane Poster Join Date: Sep 2009
Member: 1109445 Status: Offline Thanks Meter: 5 | |
09-05-2009, 15:48 | #3005 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: I.N.D.I.A(PUNJAB)
Member: 309398 Status: Offline Sonork: 100.1590052 Thanks Meter: 5,455 | Quote:
http://forum.gsmhosting.com/vbb/showthread.php?p=4722400 br. | |
09-05-2009, 15:48 | #3006 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Azerbaijan,Baku Age: 39
Member: 520916 Status: Offline Sonork: 100.1605616 Thanks Meter: 53 | Nokia 6500c media memory corrupted.memory will be formated it is log with UFS 1ST BOOT : C0,07 [Rm-265] [2.0.9.0] RAPx ID : 000000010000022600010006010C192101003000 EM 1 ID : 00000295 EM 2 ID : 00000B22 RAPx PBID : 0C800216B9A54F5097D6F1CBF693DD3CA01D6C32 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00EC220C-00008921, Sam K8F1215ETM CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_xsr15.fg, Ver: 1.40.0 CMT KSIG0 : D0D8948DEF333BF18141EF4C3D0FB1B002EB5D88 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm265__06.61.mcusw CMT NOR Erase Area: 0x00000000-0001FFFF CMT NOR Erase Area: 0x00040000-000BFFFF CMT NOR Erase Area: 0x000C0000-0013FFFF CMT NOR Erase Area: 0x013C0000-0153FFFF CMT NOR Erase Area: 0x00140000-013BFFFF CMT FLASH ERASE OK, Time: 00:49 Written: 8 Certificate(s) CMT FLASH WRITE OK, Time: 11:35 IMAGE : rm265__06.61_ISM_011.image_i_ru CMT NOR Erase Area: 0x01EC0000-03F9FFFF CMT NOR Erase Area: 0x01BC0000-01EBFFFF CNT FLASH ERASE OK, Time: 00:15 DATA_BLK_ERROR at: 0x00004000, 00 ERR: CNT FLASH WRITE D_BLK 000000000000000910000000B172, LN: 0x004000, Time: 00:04 Process Failed, Repowering Mobile |
09-05-2009, 19:49 | #3007 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1053265 Status: Offline Thanks Meter: 0 | sci phone i68 problem hi dude, i have sciphone i68 phone... i pressed on high speed sim option in engineering mode ..what is the procedure to step up my phone to act well .... |
09-06-2009, 11:26 | #3011 (permalink) |
Junior Member Join Date: Aug 2009 Location: bardoli, di.surat. GUJARAT
Member: 1108634 Status: Offline Sonork: tahir_patel Thanks Meter: 0 | i have nokia 6630. it has network problem. i can see full network on display, but my phone is not working for outgoing or incoming calls |
09-06-2009, 12:59 | #3013 (permalink) |
Major Poster Join Date: Feb 2009
Member: 978381 Status: Offline Thanks Meter: 2 | MCU ID: 0x2292 FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... Changing mode... Failed!!! Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-305\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-305\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-305\ Scanning ini files... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-305\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-305\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.910 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.91aa CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm3050_nai5.91aa ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Dannish,Norwegian,Swedish Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.910 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x74888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: af Loader is ready... P-key nokia module version 01.02 MSID: 84E501CC5AD938DD4D666DBC66 MSID decoded: 3E4EBAE900D2053CA9000000 FAID: 140022A565B58AB87B267F98 Operation took 0 minutes 7 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 0179FFFF... Erasing area: 017A0000 - 017EFFFF... Erasing area: 01F00000 - 01FDFFFF... Operation took 1 minutes 17 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 19 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.91aa Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x74888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: af Loader is ready... P-key nokia module version 01.02 MSID: 841E1EC347EFE233EF69758AD2 MSID decoded: 3E4EBAE900D2053CA8000000 FAID: AA85430A696F01AAA47612CF Operation took 0 minutes 7 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0125FFFF... Erasing area: 01260000 - 0175FFFF... Operation took 0 minutes 50 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 21 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm3050_nai5.91aa Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x74888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: af Loader is ready... P-key nokia module version 01.02 MSID: 841E1EC347EFE233EF69758AD2 MSID decoded: 3E4EBAE900D2053CA8000000 FAID: AA85430A696F01AAA47612CF Operation took 0 minutes 7 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01760000 - 0179FFFF... Operation took 0 minutes 2 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 2 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Flashing Done! Operation took 3 minutes 41 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! bhailog please help me |
09-06-2009, 13:00 | #3014 (permalink) | |
Member: 978381 Status: Offline Thanks Meter: 2 | Quote:
FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... Changing mode... Failed!!! Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-305\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-305\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-305\ Scanning ini files... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-305\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-305\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.910 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.91aa CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm3050_nai5.91aa ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Dannish,Norwegian,Swedish Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.910 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x74888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: af Loader is ready... P-key nokia module version 01.02 MSID: 84E501CC5AD938DD4D666DBC66 MSID decoded: 3E4EBAE900D2053CA9000000 FAID: 140022A565B58AB87B267F98 Operation took 0 minutes 7 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 0179FFFF... Erasing area: 017A0000 - 017EFFFF... Erasing area: 01F00000 - 01FDFFFF... Operation took 1 minutes 17 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 19 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.91aa Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x74888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: af Loader is ready... P-key nokia module version 01.02 MSID: 841E1EC347EFE233EF69758AD2 MSID decoded: 3E4EBAE900D2053CA8000000 FAID: AA85430A696F01AAA47612CF Operation took 0 minutes 7 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0125FFFF... Erasing area: 01260000 - 0175FFFF... Operation took 0 minutes 50 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 21 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm3050_nai5.91aa Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x74888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: af Loader is ready... P-key nokia module version 01.02 MSID: 841E1EC347EFE233EF69758AD2 MSID decoded: 3E4EBAE900D2053CA8000000 FAID: AA85430A696F01AAA47612CF Operation took 0 minutes 7 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01760000 - 0179FFFF... Operation took 0 minutes 2 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 2 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Flashing Done! Operation took 3 minutes 41 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! healp me | |
09-06-2009, 13:14 | #3015 (permalink) |
Freak Poster Join Date: May 2008
Member: 767389 Status: Offline Sonork: umair666 Thanks Meter: 32 | help me please need help really http://www.megaupload.com/?d=BDUWFKNT check this link please sim jumper's okay but still showing insert sim please hlp me http://www.megaupload.com/?d=KRDTIYH9 this 's pic of mmc jecket i have 1 print missed from this board please any saluton of both i really want t both salutions please send meany salution with pictures thanks tooo allz |
Solving Your CDMA Problem Within 24 hours | kapil2007chakde | Various CDMA/TDMA Cell Phones | 770 | 04-20-2017 22:20 |
..::solve Your Problem Within 24 Hours::.. | RIZWANJAT | Nokia Hardware & Hardware Repair | 16 | 02-03-2013 08:50 |
