Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 03-06-2009, 15:08   #1651 (permalink)
Member: 561916
3250 Dead
please help me ,
3250 is plus= minus shorting and pic dead .....
what can i do ....
any body help me....
Old 03-06-2009, 17:09   #1652 (permalink)
Registered User
Member: 734469
nokia 1600, 3100 etc contact service after I Flash the set I kept set in normal mode in J A F it shows insert sim But insert battery it shows contact service. hardware ok. Please solve my problem thanks for Advance
Old 03-06-2009, 17:23   #1653 (permalink)
Registered User
Member: 734469
3110c security coad I have J A F so i try user coad edit, factory settings and also flashing when i flash set is dead after try finally set on but still it asking security coad.I am also try master coad.
Please Solve My problem
Old 03-07-2009, 09:01   #1654 (permalink)
Member: 432743
init simlock with ufs etc, everything ok
Old 03-07-2009, 09:04   #1655 (permalink)
Member: 432743
Originally Posted by jodhpur_raj View Post
i need 6500c camera standby soluitions
change flexible.........
Old 03-07-2009, 10:33   #1656 (permalink)
Member: 249570
full flash then format
Old 03-07-2009, 12:41   #1657 (permalink)
Member: 798706
Originally Posted by makkah mobile View Post
i hv solved this problem 15 hours ago
nokia 3110 bord short plz u help me
Old 03-07-2009, 12:48   #1658 (permalink)
Member: 798706
Old 03-07-2009, 17:58   #1659 (permalink)
.:==di@bila==:.'s Avatar
Member: 254137
Sonork: 1592525
1110, no light on screen and keypad
Old 03-08-2009, 14:29   #1660 (permalink)
shachash's Avatar
Member: 51905
N73 usb not working, i changed the ic but still usb cannot detect, any solution?
Old 03-09-2009, 04:00   #1661 (permalink)
Member: 990117
hello,
i have a nokia 6300,but for some reason it can no longer switch on.i have tried charging/swapping the battery and sim cards but although the blue side lights sometimes flash,but still won't on......
Old 03-09-2009, 16:34   #1662 (permalink)
Member: 577307
1st check VBAT to L2400, 2nd C 2400 to display connector 6th pin,3rd V2400 to 7th pin display connector if these are ok, then check L2400 and check any resistor is connected in bit ween L2400 and lighting ic if resistor is open then make jumper. If problem is not solved then change lighting ic.
Old 03-09-2009, 18:49   #1663 (permalink)
Member: 990215
Originally Posted by pupaji View Post
Respected friends....
post your problems here.........I will try to solve that by pic within 24 hours.......
best reguards....
hi bro, i have nokia 6500 slide fone, i have problem of camera on stand by n video songs not working, there is missing suporting components of camera. do u have any solution in the shape of jumpers. plz tell me if u have any solution . bcoz i dont have components of camera. plz
The Following User Says Thank You to daaim576 For This Useful Post:
Old 03-10-2009, 06:58   #1664 (permalink)
dey mobiles's Avatar
Member: 799558
Sonork: 100.1597534
Bro nokia 1110 no charging when i connect the charger only beep and on display not showing any chargeing bars but after one hour when i unplug the charger the battery is empty there is no charge in the battery please help me........................
Old 03-10-2009, 07:35   #1665 (permalink)
Member: 685485
hi friends my 6020 mobile is being white screen i flashed it but still it is in same problem pls help me
Solving Your CDMA Problem Within 24 hours kapil2007chakde Various CDMA/TDMA Cell Phones 720 Yesterday 01:15
..::solve Your Problem Within 24 Hours::.. RIZWANJAT Nokia Hardware & Hardware-Repair Area 16 02-03-2013 07:50
Page generated in 1.54910 seconds with 12 queries
