Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 06-15-2012, 20:02   #5671 (permalink)
Member: 1485341
i need how to replace mic in e52
Old 06-16-2012, 09:53   #5672 (permalink)
Member: 1763763
what is boot ic
how to now boot
Old 06-16-2012, 09:57   #5673 (permalink)
Member: 1763763
ashu
what is boot ic how to now
Old 06-19-2012, 12:13   #5674 (permalink)
Member: 1588228
nokia e5 no network operator found plz help me???????????????????
Old 06-19-2012, 20:31   #5675 (permalink)
Member: 303663
Hi, Mahbubalfa! Could You help me with a Nokia 7610 Supernova white LCD? Which is te IC to change or resolder? Thanks TRIM
Old 06-20-2012, 13:14   #5676 (permalink)
Member: 1073684
HI.. how i can remove contact service in Nokia c2-00 please!!
Old 06-23-2012, 13:28   #5677 (permalink)
Member: 716634
6303
6303 battery connector ways
camera not working and no charge due 2 battery connector
Old 06-24-2012, 10:15   #5678 (permalink)
Member: 1774323
e63 no display but keypad lights on
Old 06-25-2012, 08:59   #5679 (permalink)
Member: 1775031
Sonork: thiru
Nokia 5230 charging way ?
Old 06-26-2012, 12:19   #5680 (permalink)
Member: 1590481
hi dear
I have Nokia N-8 & I have updated my Nokia N-8 but i want to downgrade it to it's original OS Anna, kindly help me to downgrade it and let me know where can i find the Original OS and how to downgrade it because more of Social media and other application don't support new OS which i have updated .... i'll be thankful to you in advance for your kind help
Old 06-26-2012, 18:44   #5681 (permalink)
Member: 978659
i have nokia 3110c and 5130 xm when
i changed their power ic they switched
on but after some time again dead. I
rehot the ic it switched on but then again the same story and so on. The
solution plz.
Old 06-26-2012, 20:29   #5682 (permalink)
Member: 1620700
Hi Nokia C2-06 dead...
Thank you very much
Old 06-28-2012, 09:05   #5683 (permalink)
Member: 1777847
mini display of nokia 6085 is showing time but when i close or open the fold,main screen dont go off and mini display dont lights or in other words,mobile dont responds on fold closing or opening...
Old 06-28-2012, 13:44   #5684 (permalink)
Member: 1161579
when i tried to flash x2-01 i got the below errors.
registered to: abdull
Connect phone on selected interface...
Core : v1.45 , FlashEngine : v1.40
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm709__08.71.mcusw
PPM : rm709__08.71.ppm_mk1
CNT : rm709__08.71_003.image_mh1_ctv_in_9l3w2
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
--- Insert cable and charger or press phone's power button! ---
Connection opened successfully
Waiting for communication response...
BootRom : Verify Error
Try again...
-> Error answer from BootRom
-> Boot fail...
Flashing failed...
Check files done...
BootRom : 1st boot ok
ASIC ID: 000000000000000022000509200C0000
CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB
EM0 ID: 00005361
PUBLIC ID: 00000000008161E65C88FBCFD4B2A20FC4BACE90
ASIC MODE ID: 00
ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
ROM ID: DE56D582BDDE7A3A
Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.2.0
Processing RAWLOADER...
FLIC : 00300020
Req : XSR 1.6
Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.2.0
Processing PASUBTOC ...
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:01
Reopening the connection...
Waiting for response: 30
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : blank (Erased or HW failure)
ADL: phone is in flash mode
Backup enabled, will read all certificates...
Reading NPC certificate...
IMEI : 359771045839092
Reading CCC certificate...
Reading HWC certificate...
Reading R&D certificate...
Reading VARIANT certificate...
Reading PARTNERC certificate...
Reading MDM_KEYS certificate...
Cert Read done!
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\128\BEST\Backup\Cert\359771045 839092_CRT_2nd.rpl
===Flashing [MCU]===
Erase : Processing rm709__08.71.mcusw
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:00
Write : Processing rm709__08.71.mcusw
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [ADA]
Write cert error : 82106D00
Write cert failed!
Elapsed: 00:00:11
Old 06-29-2012, 11:39   #5685 (permalink)
Member: 510389
e63 not charging solutine i change b.t ic
Tell me any kind of se problem,i will tery to solve it only in 3 hour........ roney_nexus Sony Ericsson 1670 04-25-2013 04:30
post all nokia software problem here, i will try to solved. shahinahmed007 Nokia Base Band 5 ( BB-5 ) 144 02-10-2013 02:17
every time i have face this problem now i have to solved it m s s spk MT-BOX 8 01-31-2010 01:18
W900i i try to do it flash in Cruiser riyadhkhalid Cruiser Suite 3 02-27-2006 20:44
Page generated in 0.37990 seconds with 12 queries
