Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 02-07-2010, 12:34   #61 (permalink)
rumenshom's Avatar
Member: 899774
Sonork: 100.1586303
mahabub bai
5630d mic not working
mic way?
Old 02-07-2010, 12:51   #62 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274
Originally Posted by akashub View Post
need help for N73 white hang when tryed to flash the fone set totaly dead need help shows some like this dlk black error RX2 pin is not connected need help
Bro.try to mx key use 7pin cable & flash latest version.
result post here.
The Following 2 Users Say Thank You to mahbubalfa For This Useful Post:
Old 02-07-2010, 12:54   #63 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274
Originally Posted by rumenshom View Post
mahabub bai
mic way?
Bro.use original mic.
market mic not working.
result post here.
The Following 3 Users Say Thank You to mahbubalfa For This Useful Post:
Old 02-07-2010, 12:55   #64 (permalink)
Member: 613724
Sirmy 1661 withe lcd on startup & Hang
Old 02-07-2010, 13:24   #65 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274
Bro.jast rehot this upp.
result post here.
The Following 8 Users Say Thank You to mahbubalfa For This Useful Post:
Old 02-07-2010, 14:17   #66 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1586890
bro one more wit another n73 display problem blue blank.......... i try to change display connecter but no sucsses imcoming outing evrything ok but only display problem........ any solution???
The Following User Says Thank You to akashub For This Useful Post:
Old 02-07-2010, 16:17   #67 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274
Bro.try this solution.
The Following 6 Users Say Thank You to mahbubalfa For This Useful Post:
Old 02-07-2010, 20:56   #68 (permalink)
reaj's Avatar
Member: 631470
Download>>>>>>>>>>
The Following 5 Users Say Thank You to reaj For This Useful Post:
Old 02-08-2010, 00:21   #69 (permalink)
Member: 1195919
Ashad Bro..
Hi E90 mic problem
Two of four prints are broken
Solution plz
Old 02-08-2010, 04:17   #70 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1586890
keypad not working e61i..... need keypad ways for e61i.... any tested solution pls
Old 02-08-2010, 07:58   #71 (permalink)
tchinidor's Avatar
Member: 422574
hi / slm
bro ashad i have 1202 light probleme
no water
need LCD ways and LIGTH ways
help plz
Old 02-08-2010, 08:56   #72 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274
Originally Posted by tchinidor View Post
hi / slm
no water
help plz
this solution made by hum
The Following 4 Users Say Thank You to mahbubalfa For This Useful Post:
Old 02-08-2010, 09:04   #73 (permalink)
tchinidor's Avatar
Member: 422574
slm
need 1680c key ways or other solution keybord
thank you for all hepls MR ashad
Old 02-08-2010, 09:34   #74 (permalink)
Member: 792254
Sonork: al_jadeed
boss 7610s display problum plz help
Old 02-08-2010, 09:40   #75 (permalink)
Member: 661195
Unhappy n70 Charging Problem
Bro...Help me please...I have n70 with water damage. Charging path is full short to ground .but phone is power on normally. I put the charger very heat n4201(ape regulator),n4200(SMPS) and n2300(TAHVO).I check L200,F200,V200,C200,V7501,R7556,L2301.After I Remove N4201 (It’s Very heat when I put the charger). Now Phone is switching on and Hang. No display. Only lcd light. I can’t power off the phone. How can I find this Problem? Help me please......[EMAIL="geeth_mobile@yahoo.com"]
Tell me any kind of se problem,i will tery to solve it only in 3 hour........ roney_nexus Sony Ericsson 1670 04-25-2013 04:30
post all nokia software problem here, i will try to solved. shahinahmed007 Nokia Base Band 5 ( BB-5 ) 144 02-10-2013 02:17
every time i have face this problem now i have to solved it m s s spk MT-BOX 8 01-31-2010 01:18
W900i i try to do it flash in Cruiser riyadhkhalid Cruiser Suite 3 02-27-2006 20:44
Page generated in 0.37923 seconds with 12 queries
