Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 02-11-2010, 08:35   #106 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274
Originally Posted by mbiborna View Post
1110 all is ok but after 1 min later white lcd, any solution bro....???
Bro.1st change lcd.
if not work
rehot this upp.
The Following 3 Users Say Thank You to mahbubalfa For This Useful Post:
Old 02-11-2010, 09:00   #107 (permalink)
mbiborna's Avatar
Member: 770503
Originally Posted by ashad420 View Post
Bro.1st change lcd.
if not work
rehot this upp.
Thanks ur replay already tru bro. but same.
The Following 3 Users Say Thank You to mbiborna For This Useful Post:
Old 02-11-2010, 09:31   #108 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274
Bro.replace upp...............
The Following User Says Thank You to mahbubalfa For This Useful Post:
Old 02-11-2010, 14:39   #109 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1586890
bro i need solution for e61 keypad way
Old 02-11-2010, 15:46   #110 (permalink)
Member: 993362
n82 main camera not work, after on camera show only black screen & camera option work fine only camera black problem, front camera work fine, help me sir what i do ????????
thanks
Old 02-12-2010, 07:25   #111 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1586890
16600,1110 n 2310 insert sim problem .. i try to change sim ic but no sucesse when chek the oms it show correct but after when insert the sim n battery it displays insert sim again.......... again if check the oms... there will b tw0 ground...... any soluttion for it?
Old 02-12-2010, 07:43   #112 (permalink)
Member: 1230819
Bro.1st try flash latest version
result post here.
Bro, i have submitted mobile to Service center. Initial investigation shows that Network IC of N81 is not working. He still investigating the problem. Can you suggest any particular areas to look for?
Old 02-12-2010, 11:35   #113 (permalink)
Member: 817864
Unhappy 5800 lock switch
5800 lock switch broken with tracks from board
any tricky jumper setting for it please
Old 02-12-2010, 15:38   #114 (permalink)
$ktelecom's Avatar
Member: 484060
Sonork: 100.1596821
nokia n70 mmc not work chang mmc ic but same ecery time show no memory card inserted plz help me
Old 02-13-2010, 05:54   #115 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274
Bro.try this solution.
The Following 7 Users Say Thank You to mahbubalfa For This Useful Post:
Old 02-13-2010, 05:57   #116 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274
thanks
Bro.1st change camera.
if not work
try this solution.
The Following 5 Users Say Thank You to mahbubalfa For This Useful Post:
Old 02-13-2010, 05:59   #117 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274
Old 02-13-2010, 07:20   #118 (permalink)
Member: 546351
sir 7210c contact service pls help me
Old 02-13-2010, 07:54   #119 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1586890
repair
thaNK u for the good solution keep it up bro....
Old 02-13-2010, 07:56   #120 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1586890
bro but u still dint gave any solution for e61 keypad
ways
Tell me any kind of se problem,i will tery to solve it only in 3 hour........ roney_nexus Sony Ericsson 1670 04-25-2013 04:30
post all nokia software problem here, i will try to solved. shahinahmed007 Nokia Base Band 5 ( BB-5 ) 144 02-10-2013 02:17
every time i have face this problem now i have to solved it m s s spk MT-BOX 8 01-31-2010 01:18
W900i i try to do it flash in Cruiser riyadhkhalid Cruiser Suite 3 02-27-2006 20:44
Page generated in 0.22284 seconds with 12 queries
