Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > SWIFT Platform
SWIFT Platform D500, D508, D510, D600, D608, D800, D820, E340, E350, E640, E730, E760, T309, T809.
Old 07-21-2005, 13:50   #1 (permalink)
Member: 115777
D500 Flashing Help
I have a d500 serial cable for flashing(with 9v) on it. I have used this cable to unlock an older d500 using winimei and had no probs.
I have a newer d500 now from April 2005 on orange and am trying to unlock and flash it as i want to use it on o2 but when i power the phone on in winimei when asked it doesnt go into tat mode , it goes straight to insert sim screen. I have tried to get phone into tat mode using winimei 1.07 & 1.34 , samsung d500 flasher by nasiriyan and sgh d500 downloader v3.2 but all timeout as phone goes straight to insert sim screen.
I have tried changing com port settings but still nothing.
Can new d500 be flashed ?
Do i need different software to flash newer d500???
Cant seem to find any1 else with this same problem - any help appreciated....
S/W Version = D500 BVEB1_ED1 XAED1 Orange
H/W Version = MP 3.601 02:10:44 April 09 2005
Old 07-21-2005, 14:09   #2 (permalink)
blaiseid's Avatar
Member: 37735
Hi, I need the D500 O2 FLASH FILE, May you send it to blaiseid@yahoo.ca or post it here?
About Flashing the D500, use Corona v3.2,Set Braud to 43xxx and clip start,press power button, if phone switches on, switch it of and press on again.
I install the vertual drivers and I can flash the D500 in 24 minutes(BOTH FILES) using COM1
Old 07-21-2005, 19:36   #3 (permalink)
Member: 115777
i only have serial cable (designed for flashing but doesnt seem to be working)as above and datacable used with easystudio 2 cannot get either to workin corona 3.2..
has any1 managed to flash newer version of this phone?
flash file i have is unbranded not 02...
this is datacable i have
http://allgsm.co.uk/product_info.php...20f0cdd7d16afe
Old 07-23-2005, 04:44   #4 (permalink)
Member: 152719
http://www.smart-fans.com/D500flash.jpg
i know the usb d500 is service cable..is faster than com port.
==>www.smart-fans.com/item.htm
Old 07-24-2005, 12:17   #5 (permalink)
Elioni's Avatar
Member: 141682
I Bought Cable D500 With Twister Crack For Use To Ufs2
I Trayed Today But Box Cant Read The Phone
Can Twister Crack (activisation D500 Twister) Unlock D500?
Old 07-24-2005, 15:50   #6 (permalink)
Member: 136598
yes it can unlock it click unlock it will say i cant do it via cable but i can generate keys it will generate a unlock code insert a locked sim enter the code the phone is now unlocked that is all you can do using the activation thing for d500
Old 07-26-2005, 17:07   #7 (permalink)
Member: 104571
hi guys
what software did you use to flash D500?
thanks before
Old 07-26-2005, 18:07   #8 (permalink)
mohammad2004's Avatar
Member: 71144
i need a software for flasher d500 but no comport by usb
please help me
Samsung D500 Flash Help Plz? mint centre NSPRO 2 03-06-2007 12:03
d500 flash help henrybuoy SWIFT Platform 3 12-14-2005 19:47
d500 flashing help ronnyj1 NSPRO 2 08-23-2005 07:52
d500 flashing help! James-R NSPRO 2 08-16-2005 23:39
D500 flashed, IMEI changed help! marqwui SWIFT Platform 1 01-10-2005 02:09
Page generated in 0.30210 seconds with 11 queries
