SWIFT Platform D500, D508, D510, D600, D608, D800, D820, E340, E350, E640, E730, E760, T309, T809. |
12-02-2005, 15:24 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: ALGERIA Age: 46
Member: 174203 Status: Offline Thanks Meter: 15 | d500 hang after formating with corona32 any solution for this problem?!! |
01-14-2006, 10:37 | #6 (permalink) |
No Life Poster Join Date: Nov 2004 Location: In a Ganja plant! Age: 38
Member: 91298 Status: Offline Thanks Meter: 6 | Do the following my friend - format both parts of flash - then fully flash the phone... Once flashed... power up the phone and do *2767*2878# and *2767*3855#, once this is done you can then rebuild nvm area using winimei or any samsung program that will let you re-write imei, then put imei in and rewrite it - once the imei has been rewritten to the phone just do and unlock, now you have your d500 fully reflashed and the nvm area fully rebuilt. We do this with every samsung we can (formatting before flash etc) as this makes sure the phone is fully ready for the new flashes(es). We have also noticed that if you flash it normally then sometimes you can still have bugs and errors - especially with TFS flashing. br, Danny. |
01-16-2006, 23:01 | #7 (permalink) |
Insane Poster Join Date: Dec 2000 Location: AP/GLD
Member: 2852 Status: Offline Thanks Meter: 0 | D500 key freeze I have a D500 with key lock, first i read the code with tst Swift, then i resetted with winimei etc etc. Finally i flashed it with corona 3.2 and still the keys are disabled, the phone only beeps when you press right button. I searched the forum and tried the things above but no succes, what am i doing wrong? Its a D500, dutch, normal Com cable. I also can't use the eprom reset code, because the keys dont respond. regards |
T280 startup hang after formating | aukonline | Infinity-Box | 9 | 10-21-2009 11:55 |
d500 hang after 5 to 10 minutes in mp3 | elhadi110 | Samsung Hardware Repair | 4 | 06-17-2009 23:21 |
n99i hang after format..flash file needed | carlluvjo | Infinity-Box | 12 | 11-22-2008 19:10 |
D500 Hang After 2-3 Minute | HAMID-GSM | Samsung Hardware Repair | 5 | 03-19-2007 18:29 |
d500 hang after 2 min | mehta | Samsung Hardware Repair | 2 | 08-28-2006 08:27 |
