D500 (reset phone lock) D500 which doesn't respond on pressing the keys, only the on/off button. Normally it should be the phone lock. I read the code with tst_swift, but the phone doesn't respond. After that i flashed it with corona 3.2, nand format and used winimei to get the correct imei, everythings goes ok, but i can't use the keys. only the cam works and on/off button. I can't reset the phone lock, it fails, also by winimei and D500 tools. I searched for the forum for my solution but with no succes, that's why this new post. I can't use the keys, so i also can't do a custom reset or full reset. What am i doing wrong here? These are the info from reading tst_swift: IMEI: 35505700099555 SW: D500BVDK8 HW: REV2.6 Provider: 204-20 Net lock code: 42404944 Phone freeze code: 03871182 Subnet lock code: 00000000 SP lock code: 00000000 Done. I use a com1 cable with 9v |
sounds more like a hardware fault,check ribbon/stuck button or veritors on main board. |
