E2130 restart problem.... E2130 restart problem.... Nobody(nspro,ustpro,z3x,hwk...) have solution for e2130 restart problem..... if anybody has solved this prob..... Please post here..... i request all samsung programmers to concentrate on this issue... |
Downloads - E2130 - GSM-data Free Gsm Support | |
Solution for e2130 restart free Quote:
flash phone with right flash jip2 in support of HWK (with HWK) then rebuild imei with ustpro tested |
will return back for repairing. br:) |
handsets will come back if only flashing done. for perfect solution open handset rehot cpu and flash ic finally flash set with good flashfile. be careful not to over heat otherwise permanent damage might occur |
flash phone with right 100% TESTEDflash jip2 in support of HWK (with HWK) ANY PROBLAM TELL ME I SOLVE UR PROBLAM |
hi Junior Member alrdy tested but not worked using any flash file using any box broblem solved white changen flash ic |
E2130 rastart problem |
It is the problem tomorrow. I tried every thing erase spring and writerd good one but still same after few days |
E2130 restart problem SOLVED Selected model: E2130 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Start TFS format... OK Start NOR flash NOR flash - ok Start Flash TFS Download - ok Elapsed time: 692 second, sw ver: 3.5.0033 |
E2130 Restart Problem. Its a manufacturer problem and its documented with solution Pls go and download the document for details download - filecloud.io |
