Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > SWIFT Platform
SWIFT Platform D500, D508, D510, D600, D608, D800, D820, E340, E350, E640, E730, E760, T309, T809.
Old 03-29-2010, 22:52   #1 (permalink)
aikonmani's Avatar
Member: 304090
E2130 restart problem....
Nobody(nspro,ustpro,z3x,hwk...) have solution for e2130 restart problem.....
if anybody has solved this prob.....
Please post here.....
i request all samsung programmers to concentrate on this issue...
Old 05-21-2010, 19:17   #2 (permalink)
Member: 235606
Downloads - E2130 - GSM-data Free Gsm Support |
The Following User Says Thank You to rayen For This Useful Post:
Old 05-30-2010, 22:05   #3 (permalink)
Member: 765817
Solution for e2130 restart free
http://harraga.no-ip.org
The Following User Says Thank You to el oudi walid For This Useful Post:
Old 05-31-2010, 00:26   #4 (permalink)
Member: 411207
flash phone with right flash jip2 in support of HWK (with HWK)
then rebuild imei with ustpro
tested
The Following User Says Thank You to blaw For This Useful Post:
Old 05-31-2010, 18:09   #5 (permalink)
BouRRi_GSM's Avatar
Member: 111457
will return back for repairing.
br
Old 07-13-2010, 16:39   #6 (permalink)
bhuvanele's Avatar
Member: 237210
handsets will come back if only flashing done. for perfect solution open handset rehot cpu and flash ic finally flash set with good flashfile.
be careful not to over heat otherwise permanent damage might occur
Old 07-30-2010, 19:01   #7 (permalink)
Member: 1304262
flash phone with right 100% TESTEDflash jip2 in support of HWK (with HWK) ANY PROBLAM TELL ME I SOLVE UR PROBLAM
Old 08-23-2010, 18:24   #8 (permalink)
Member: 1322811
hi Junior Member alrdy tested but not worked using any flash file using any box broblem solved white changen flash ic
Old 08-06-2011, 16:15   #9 (permalink)
Member: 1501876
Sonork: skamal2506
E2130 rastart problem
Old 08-08-2011, 04:05   #10 (permalink)
Member: 1557767
Sonork: lyf.hospet
It is the problem tomorrow. I tried every thing erase spring and writerd good one but still same after few days
Old 03-26-2012, 07:21   #11 (permalink)
Member: 1644200
E2130 restart problem SOLVED
Selected model: E2130
Selected com port: COM4
Selected speed port: 921600
Please, connect phone and press power button 3 seconds
Phone Detected
Sending loader1... OK
Flash ID: 08
Sending loader2... OK
Start TFS format... OK
Start NOR flash
NOR flash - ok
Start Flash TFS
Download - ok
Elapsed time: 692 second, sw ver: 3.5.0033
The Following User Says Thank You to selvam1155 For This Useful Post:
Old 10-24-2012, 07:49   #12 (permalink)
Member: 1820127
E2130 Restart Problem. Its a manufacturer problem and its documented with solution
Pls go and download the document for details
download - filecloud.io
E2130 blinking problem.... aikonmani Z3X-Team Products 7 09-04-2012 16:37
cect v180 restarting problem but after ffs same problem shripalkawdia Chinese Miracle & PinFinder 9 05-09-2009 02:06
LG KE800 restart problem but 1st problem is bluetoth Freshbol Infinity-Box 4 02-13-2008 19:14
N95 had restart problem and now have problem with sensor key Supermen! Chinese Miracle & PinFinder 2 11-23-2007 08:23
6270 startup restarting problem help big problem vinay_sharma Nokia Hardware & Hardware-Repair Area 5 07-07-2007 22:06
Page generated in 0.43333 seconds with 11 queries
