SWIFT Platform D500, D508, D510, D600, D608, D800, D820, E340, E350, E640, E730, E760, T309, T809. |
03-13-2006, 13:25 | #1 (permalink) |
Junior Member Join Date: Jun 2005 Location: UK Age: 49
Member: 155303 Status: Offline Thanks Meter: 0 | FDN restricted Just finished unlocking phone etc, but when i try to dial out it says "number fdn restricted" how do i correct this, i know its to do with a fixed dialling no, or something. FDN is enabled in menus, but i dont know what PIN2 number is and ive only 1 attempt left. Any ideas? Cheers Mick |
11-07-2008, 19:56 | #2 (permalink) |
No Life Poster Join Date: May 2006 Location: Bsb, DF Brasil
Member: 283943 Status: Offline Thanks Meter: 124 | FDN on X680 Hi, n update about this situation? Have fullflashed a x680 and the same. It refuses to make n call due to FDN activated at security menu but can enter the pin2. Tks for n reply. B. r |
11-10-2008, 15:11 | #4 (permalink) | |
Member: 283943 Status: Offline Thanks Meter: 124 | other sim Quote:
Will try with a new sim cause i dont have n with the pin2 recorded. Iam afraid it will be possible only with the sim first activated the FDN. Will let you know if i succeed. B. R | |
11-11-2008, 13:33 | #6 (permalink) | |
Member: 283943 Status: Offline Thanks Meter: 124 | FDN activated Quote:
customer brought a phone Sam X680 wich cant make n call. Always CALL REFUSED and as i check all settings foun only FDN activated and it asks for a pin2 in order to be inactivated. Have erased NOR and full flashed it back but still refuses to make n call. Think itīs due to FDN active, otherwise n other setting regards CALL proccess or security issue should be also activated. Will try the solution with a SIM i DO know the pin 2 and post result. Tks in advance. | |
11-11-2008, 13:57 | #7 (permalink) |
Member: 283943 Status: Offline Thanks Meter: 124 | Worked. Well, just for your reference i left it powered on since last night and then today it began make calls again. It was not necessary to disable FDN and i do not know what were the real solution. Now will fullflash it again in order to get portuguese language cause the one i flash last time has only europe lang + en. B. r |
11-12-2008, 07:51 | #8 (permalink) | |
Freak Poster Join Date: Nov 2007
Member: 623972 Status: Offline Thanks Meter: 26 | Quote:
sir firstly u have to do the ENTER THE CODE *#2767*2878# then check its IMEI ,ur fone will be 100 % ok | |
06-25-2016, 02:21 | #9 (permalink) |
Junior Member Join Date: Jul 2008 Location: borongan city
Member: 806184 Status: Offline Thanks Meter: 0 | Go to your Apps on your Samsung Galaxy Note 10.1 Select ‘Phone' Tap ‘Keypad' Tap on the menu icon with the keypad Choose ‘Call Settings' Tap ‘Additional Settings' Tap ‘Fixed Dialling Numbers' Choose ‘Enable FDN' Enter the PIN2 code that came with your SIM card Select ‘FDN List' Enter the numbers that you want to allow calls to be made to Tap ‘Save' |
Help ADN FDN SMS | Enzo | Sim Cloning and Scaning | 3 | 07-04-2003 13:09 |
Q: To Read Write FDN from/to SIM ? | Eurocrypt | Sim Cloning and Scaning | 0 | 06-25-2003 13:55 |
Maximum number of ADN, FDN and SMS | hakthu | Sim Cloning and Scaning | 4 | 06-11-2003 12:06 |
How to change ADN,SMS,FDN??? | elbehem | Sim Cloning and Scaning | 9 | 05-28-2003 01:14 |
311-HELP-call bared-fdn directory numbers only | CONTIRO | BF, BG, TH, BHx Series | 4 | 05-09-2003 02:02 |
