Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > SWIFT Platform
SWIFT Platform D500, D508, D510, D600, D608, D800, D820, E340, E350, E640, E730, E760, T309, T809.
Old 01-09-2005, 12:33   #1 (permalink)
Member: 1688
Full reset Samsung D500
What is the code to make eeprom reset ????
Some phones in holland have a problem
after unlock people can cal to the pone...
but you can nat make out-going calls
Old 01-09-2005, 17:31   #2 (permalink)
Member: 102996
*2767*3855# -> Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!! )
But also changes IMEI to 447967-89-400044-0
Old 01-10-2005, 13:41   #3 (permalink)
Member: 1688
no other options ????
Does this code realy change imei ???
elco ???
Old 01-10-2005, 23:16   #4 (permalink)
Member: 102996
Yeah it changes the imei but u can change ur imei back to the old one if you want with another program.
Old 01-10-2005, 23:22   #5 (permalink)
qwerthj's Avatar
Member: 22902
elco ???
I think no. I used this code on D410 and many other phone type wich have same problem (can't make outgoing call), and worked fine without imei changing. But on old phones (like sgh-2100) reseted the imei. But this phone have separate eeprom ic.
WBR
Old 01-12-2005, 16:28   #6 (permalink)
Member: 18727
which program to change it back?? lil Buffy
Old 01-12-2005, 18:40   #7 (permalink)
Member: 48092
hi i am in no way associated with barred/blocked phones, however if this code changes the IMEI then does that mean that phones barred in the uk will work?
Old 01-12-2005, 19:17   #8 (permalink)
Member: 105610
d500
does any one need a simple code for the d500 the code is so easy to use and it does not harm your phone like most of the codes do all it does is resets the wap settings!
tx 07971562115
Old 01-13-2005, 03:28   #9 (permalink)
Member: 105610
does anyone know the e800 code?
Old 02-09-2005, 22:46   #10 (permalink)
Registered User
to_deal_with's Avatar
Member: 19168
try *2767*2878# without a sim inside
how to reset user code of samsung d500 wsb SWIFT Platform 10 12-26-2011 11:01
Newgen C620 full reset or full eeprom reset gsm_unlock2 Various 1 07-08-2006 23:51
samsung d500 winimei full version needed nasirhh SWIFT Platform 3 06-21-2006 12:42
samsung x608 full reset flash SYSOL Platform 0 02-04-2005 10:46
Page generated in 0.48102 seconds with 11 queries
