SWIFT Platform D500, D508, D510, D600, D608, D800, D820, E340, E350, E640, E730, E760, T309, T809. |
10-22-2019, 19:38 | #1 (permalink) |
Junior Member Join Date: May 2016 Age: 29
Member: 2571592 Status: Offline Thanks Meter: 0 | GT-E2222 dead after flashing done Selected model: GT-E2222 Software version: 37.0 Load model info... OK Loading BIN PTT file... OK Reconnect battery and connect phone to USB cable Timeout Operation: Flash Selected model: GT-E2222 Software version: 37.0 Load model info... OK Loading BIN PTT file... OK Reconnect battery and connect phone to USB cable Timeout Operation: Flash Selected model: GT-E2222 Software version: 37.0 Load model info... OK Loading BIN PTT file... OK Reconnect battery and connect phone to USB cable Timeout Operation: Flash Selected model: GT-E2222 Software version: 37.0 Load model info... OK Loading BIN PTT file... OK Reconnect battery and connect phone to USB cable Phone detected Checking device descriptions... OK Link type set to USBF Reading OTP... OK OTP register: 00000000 Unprotected device detected Reading product ID... OK Product ID: 0x 2 4502B 06231C4 Reading SCROM version SCROM version - 0x 34 Chipset version - 0x 0A Downloading Loader in Internal RAM... OK Wait for device... OK Checking device descriptions... OK Loader verison... 7.4.7_SSG_v0.0 NOR flash memory SSG_KAP382Nxxx3 detected Flash memory parameters Capacity params: 2 Datawidth - 255 Block number - 64 Block size - 2 Buffer prog. Timing params: 700 ms erase block time - 320 us write buffer time Send Loader and NOR Flash Parameters... Loader parameters Write Test flash params: 0x0 Test Address - 0 Test size Buffer params: 0 Buffer type - 0 Buffer size - 0 Tansfert size - 0 Tansfert RAW size Bad Block params: 0 Bad block reservoir size SW Boot version: 4 Get First Block... OK Prepare FirstBlock... OK Partition Table in Firstblock needs to be updated from SW Boot file FirstBlock Must Be updated Erase First Block... OK Set Partition Params... OK Downloading FirstBlock in Flash... OK Send Verify Cmd... OK Erasing Partition_1... OK Erasing Partition_2... OK Erasing Partition_3... OK Erasing Partition_4... OK Programming Partition_1 Set Partition Params... OK Download Partition_1 LCDACT... OK Programming Partition_2 Set Partition Params... OK Download Partition_2 MAIN... OK Programming Partition_3 Set Partition Params... OK Download Partition_3 DSP... OK Programming Partition_4 Set Partition Params... OK Download Partition_4 ROOT... OK Flashing CSC... Init NAND Flash... OK Checking TFS4... OK Downloading CSC... Creating directories... OK Directories Error Check... OK Creating files... OK Closing TFS... OK Flashing CSC... OK Flashing done (time - 00:04:41) |
