SWIFT Platform D500, D508, D510, D600, D608, D800, D820, E340, E350, E640, E730, E760, T309, T809. |
02-27-2006, 19:23 | #1 (permalink) |
Insane Poster Join Date: Apr 2002 Location: E. Yorkshire (UK)
Member: 10695 Status: Offline Thanks Meter: 4 | How to Backup Samsung E800 Flash in SarasSoft I have the N-Box/UFS/Twister box with SarasSoft & HWK. I am trying to back my Samsung E800 Flash. I backed up MCU I backed up TFS No Problems. My problem is writing this back to my phone. I can write flash MCU 100% When i try to write flash TFS i get error "No CFG file" When i look in directory of flash - there are 2 files. *.bin and *.tfs How can i create the cfg files please. Thanks |
02-28-2006, 09:07 | #2 (permalink) |
Freak Poster Join Date: Aug 2002 Location: Poland / Kolbuszowa Age: 43
Member: 14277 Status: Offline Thanks Meter: 2 | when you use UFS for backup firmware... you will get 2 binary files... like you say there is no problem to write back MCU but UFS can't write binary NAND backup... so if you whant create full orginal backup form phone you must use "SGHFD (SGH Flasher/Dumper) by Alex/AT" because only this software can read software as orginal "TFS file (TFS file use *.cfg file)" and then you will be able to flash it with UFS... give me software version (press *#1234#) maybe i have it.. then i will send you.. br orcgsm |
The Following User Says Thank You to _-oRc-_ For This Useful Post: |
02-28-2006, 09:25 | #3 (permalink) |
Member: 10695 Status: Offline Thanks Meter: 4 | Hi ORC Thanks for the quick reply. Version E800AYDF1 The logos and tones are from O2 (UK) Where will i find SGHFD please. OK ORC. I think i got it (Googled it) Only problem is - i have no serial port on my PC - Only USB Thanks Last edited by bigyun2000; 02-28-2006 at 10:17. |
02-28-2006, 10:58 | #4 (permalink) |
Member: 14277 Status: Offline Thanks Meter: 2 | ok will get this fill here but you must wait about 1h. file has 8 MB... http://fonex.go.pl br orcgsm |
02-28-2006, 11:57 | #5 (permalink) |
Member: 10695 Status: Offline Thanks Meter: 4 | Hi ORC Thanks for your help. Will let you know how i get on. Is it possible to backup phone with USB at all in any program? I have no serial ports on PC? Thanks |
02-28-2006, 14:49 | #8 (permalink) |
Member: 14277 Status: Offline Thanks Meter: 2 | check when you connect e800 to usb port what devices start install then check for com port and try use them.. also check maybe your cabel emulate com port because e800 can only comunicate as serial connection... |
03-04-2006, 13:34 | #9 (permalink) |
Member: 10695 Status: Offline Thanks Meter: 4 | Hi ORC Have you a repair flash For the Samsung E800 please. I don't know what happened. I flashed My E800 and now is dead. Cannot get into TAT mode. Put battery in phone and cannot even switch phone on. Any ideas please. Info for the fone is as earlier message. Thanks ORC Regards Bigyun2000 UK |
03-04-2006, 21:51 | #11 (permalink) |
Member: 10695 Status: Offline Thanks Meter: 4 | Hi ORC Its OK false alarm. I managed to re-flash it after many goes. Its now back to normal. Only difference is its locked and allthough i select unlock and it says OK, It is really still Network locked. Anyhow i put the lock code in and all is OK now. Thanks |
03-07-2006, 12:16 | #13 (permalink) |
Member: 10695 Status: Offline Thanks Meter: 4 | Hi ORC I use N-Box with HWK. I did manage to unlock it but not directly with this. I got the network code. Entered that manuall on phone and hey presto All works 100%. Thanks for your help. Would like more info on Backing up complete phone please if you have the time. Cheers |
how to name samsung dump flash file | monti_908 | Samsung Flashers, Software, Firmware. | 9 | 04-29-2011 08:03 |
how to backup pds with Flash Backup 3.0 | hassenmobile | Motorola P2k | 1 | 06-16-2007 11:55 |
How to work with Full flash in Samsung phones ! | GSM SNIPER | UFS2 + UFS3-Tornadoflasher | 3 | 01-30-2005 08:20 |
pls, how to know which version flashed in to A50 - need fo reflashing | -=ELF=- | x1x to x45/x50 | 2 | 05-19-2003 16:14 |
