Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > SWIFT Platform
SWIFT Platform D500, D508, D510, D600, D608, D800, D820, E340, E350, E640, E730, E760, T309, T809.
Old 12-02-2006, 14:06   #1 (permalink)
Dr cellular uk's Avatar
Member: 182216
Thanks Meter: 24
i am the D500-D600 samsung repair expert
any problems relating to these modles i will help you......
The Following 7 Users Say Thank You to Dr cellular uk For This Useful Post:
Old 12-02-2006, 14:11   #2 (permalink)
The Repair Shop's Avatar
Member: 307549
Thanks Meter: 188
ok then how about this.
No sound from the main speaker on the sub pcb? how to fix it without replacing the sub pcb?
The Following 2 Users Say Thank You to The Repair Shop For This Useful Post:
Old 12-02-2006, 14:21   #3 (permalink)
Kanwalgee's Avatar
Member: 68392
Sonork: 100.100701
Thanks Meter: 658
I have d500 its ring sound is too slow i change ringer also change lcd strip any solution.
Old 12-02-2006, 19:03   #4 (permalink)
Member: 182216
Thanks Meter: 24
sorry for late reply guys im at work,to answer you simzmobiles what phone are you refering to? d500? if it is you should resolder the last 3 pins on the main connector on the pcb from the right sorry i cant send you a picture as im at work now will try send later,just above the 2 miniature diodes,resolder the connector pins 2 and 3 from the right.....
Old 12-02-2006, 19:06   #5 (permalink)
Member: 182216
Thanks Meter: 24
as for you "malikgee" you said the ring sound is to "slow" or did you mean to low? did you change the sub pcb? or reflow the sub pcb?
Old 12-02-2006, 19:06   #6 (permalink)
Member: 307549
Thanks Meter: 188
yes it was the D500.
If you can a pic would be great
Cheers Simz
Old 12-02-2006, 19:09   #7 (permalink)
Member: 17243
Thanks Meter: 13
D600 , Restarting ( Only Showing D600 When It Power On And Its Off Then Restarting ) I Flashed It But Same
Any Solution...
The Following User Says Thank You to mandu For This Useful Post:
Old 12-02-2006, 19:54   #8 (permalink)
Member: 143848
Thanks Meter: 125
Any Solution...
if u havent forgot to put the green tap on both flex connectors .. (90%)
and flashed the phone too and dint work you are in same ***** as mine(8%)
i m looking for that solution too
regards
Old 12-02-2006, 23:29   #9 (permalink)
Member: 182216
Thanks Meter: 24
hi mandu most times when d600 restarts if not liquid damaged change the ribbon or check the battery contacts.....the green tape wont make any difference if on or off as long as the connector clip is locked the ribbon should be safe....replace the ribbon hi chances that is the problem.....
The Following User Says Thank You to Dr cellular uk For This Useful Post:
Old 12-03-2006, 07:51   #10 (permalink)
Member: 17243
Thanks Meter: 13
Thanks For Your Replay
My Phone Is Not Liquid Problem
I checked Display Flex And Its Green Tap , I Put Additional Tap Also
And I Try To Work Phone With Out Closing
The Same Symptom ...
Old 12-03-2006, 13:03   #11 (permalink)
Kanwalgee's Avatar
Member: 68392
Sonork: 100.100701
Thanks Meter: 658
Sory for mistake too low bro
Old 12-03-2006, 13:07   #12 (permalink)
Member: 182216
Thanks Meter: 24
try re heat the mcu ic and eeprom DO NOT OVERHEAT THEM????? just a little heat,if all fails you have a serious problem....most of the time when i have these problems all works for me....it is a good sign that you managed to upgrade the software,with these types of phones usually the faults are simple,one more thing you can try,change the crystal underneath the speakers on the main pcb,it is probably faulty and and not occsilating at the right frequency to power up properly...
Old 12-03-2006, 13:10   #13 (permalink)
Member: 182216
Thanks Meter: 24
hi simzmobiles did you manage to fix your d500? post me result?
Old 12-03-2006, 13:16   #14 (permalink)
Member: 307549
Thanks Meter: 188
Not yet, i was hopeing for a pic off where to reheat it?
cheers
Old 12-03-2006, 14:46   #15 (permalink)
Member: 137290
Thanks Meter: 2
hello
i have d500 keypad prblem
help me please
I Am The Expert For Flashing 1110-1600-2310.... bouziane1 Nokia Digital Core Technology 4 ( DCT-4 ) 26 10-17-2008 14:02
need software for samsung for ufs d500 d600 digitalmk Samsung Flashers, Software, Firmware. 0 07-07-2006 11:24
samsung d500/d600 USB unlock cable henrybuoy Wanted Products 2 01-27-2006 13:27
D500 / D600 Imei Repair Is It Possible With Hwk a5hgr HWK 9 12-14-2005 11:00
Page generated in 0.26610 seconds with 11 queries
