samsung D500 what software and cable to use for unlock/imei change on D500, i have V200 cable, will this do, and i have E700 cable also |
im also looking for the solution!!!!!!!!!! |
D500 Cable Hi Guys, Have you got the solution for the cable???? Does anybody have the cable schematic??? The software, I already have, but I need the cable schematic!!!! The E700 cable doesn't work with this software, pinouts must be changed. any solution??? Please contact me if you got any solution for the cable, then I can share te software to you. Sweden Mobile [email protected] |
d500 blocked but working on t-mobile??? hi guys , i bought a d500 out of the loot , it's orange branded , and worked fine for a few days , then limited service with my o2 sim , tried vodafone and orange , o2 and orange both say limited service and vodafone gets signal but wont make or recieve calls ....thus meaning the handset is barred yes i know BUT i have the latest type of T-mobile pay as u go simcard (the type that dont work in the nec616v when unlocked due to either some sim profile or sim voltage issue )anyways i popped this in and wolaa ... makes / recieves calls /txts /mms + bluetooth all fine ...anyone else come across this ? , ok it might only be a TEMP solution (its working alot better now than it was 5mins ago collecting dust!!) in given time till talented individual codes up some soft (ahum!!) .. post your results those who have a t-mobile simcard bought in the last month say cheers fr33s0ft |
wbr imran_k |
Each phone has the unique IMEI, Serial, & Bluetooth numbers, matched each other.When you write IMEI number, you have to use the one & only matched Bluetooth number.Unique Bluethooth nubmer is checked by keystring (*#232337#) or by AnySVC searching. This its information that Samsung give for IMEI change on D500.So its not so simple to change IMEI on D500 phones. |
Cable Schematic for D500 Hi Is there anybody have the d500 cable schematic??? The cable pins is not same as e700 Please add me on MSN or send me email. Thx Sweden Mobile [email protected] |
you said you have soft , which soft you want to use? For cable: Is there a original cable on market, i dont know? |
hi there I got a d500 from orange any chance of how to add a different language? thanks :) |
hi there I got a d500 from orange any chance of how to add a different language? thanks |
i have the shematic of d500 send me the prog and i will send the pinout |
I Need Also Unlocking Solution Of This Phone Dose We Need To Change Its Pinouts?? Regards Gsm Mind Stand Alone |
1 Attachment(s) WinIMEI for D500 + pinout |
In the Noikafree calc it gives this code: Model: Samsung SGH-D500 #*7337# What does this code do? is it ment to unlock it ? |
Why don't you try to read/search the forum? The answer is posted many times! The code will only unlock the first version(s) of D500, but not newer versions. |
