SWIFT Platform D500, D508, D510, D600, D608, D800, D820, E340, E350, E640, E730, E760, T309, T809. |
12-20-2005, 13:51 | #1 (permalink) |
Junior Member Join Date: Sep 2003
Member: 38196 Status: Offline Thanks Meter: 0 | winimei change imei problem i have a 9v comm port cable and winimei 1.37 and also winimei 1.01 when i use 1.37 the "change bt id" button along with "new" and also "wrt bt" & "wrt imei" are grayed out so i cant use them when i use winimei 1.07 (i think its that, not sure but it doesnt give a lot of countrys) i can change the bluetooth id, but when it comes to changning the imei, and it asks for TAT mode, i can get into TAT mode but then get FAILED in the top right hand corner of the screen (winimei) and this error message Failed In Reading Phone's Version ! Reading...Version...Wait... Success in Entering the TestMode In 13sec...! Waiting for Entering the TAT Mode! ? can some one please tell me if this is because its a O2 firmware phone and that the winimei instructions say to use UKorange? if so, the older version of winimei only has orange on it and not o2 were as the 1.37 has o2 BUT has the fuctions grayed out, please help as this is driving me crazy i have done a search but all people seem to do is say "iv fixed it and iv done it" with out explaining HOW? is FIRMWARE the same as PHONE version? software version is d500addl3_ed1 xaed1 02ukpo hardware version is mp 3.601 03:19:41 date is apr 09 2005 please someone help Last edited by promethus; 12-20-2005 at 16:22. |
12-20-2005, 20:35 | #2 (permalink) |
Member: 38196 Status: Offline Thanks Meter: 0 | sorted it, well it had nothing to do with the software or the phone, it was the comm port on me puter... hooked it up to me friends comp an worked strait away, also for all those having problems with getting it to TAT mode, leave the phone unplugged and turned off with the sim OUT till it says WAITING TO ENTER TAT MODE then ( you need to be fast ) plug the phone into the comm port cable (make sure the 9v square battery is new and plugged into the cable) and then press and hold the power button on the phone till it says in big red text TAT MODE |
12-22-2005, 12:17 | #4 (permalink) |
No Life Poster Join Date: Nov 2004 Location: In a Ganja plant! Age: 38
Member: 91298 Status: Offline Thanks Meter: 6 | I had the same problem with a newly flashed d500 (it had no imei either) so i had to reset the phone using codes before it would read version with winimei |
3120 change IMEI - problem | pacoleczo | Twisterflasher | 7 | 11-15-2005 09:44 |
x600 change imei problem | nica | SYSOL Platform | 0 | 06-15-2004 00:50 |
BE4 Change IMEI problem solved! | expert | Alcatel & TCL Old Models | 24 | 02-25-2004 13:21 |
Change IMEI problem - Sim Card Not Accepted | TheEckoMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 09-02-2001 12:50 |
