QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
02-21-2009, 01:22 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Poland
Member: 653932 Status: Offline Thanks Meter: 63 | [F480] installing new widgets, deleting unnecessary files this time is for playing with f480 heavily we cannot still modify two the most important files of the firmware [.bin and .rc1] yet from some time there is a way to modify .ffs file what can we do through that? - delete unnecessary images, wallpapers or tones - delete/remove locked games - add games without necessity of uploading them later - install new widgets offline we need: - winimage program http://ourworld.compuserve.com/homepages/G...nt/download.htm - ffs file from the firmware we want to modify - widgets or widget pack eg. http://www.mediafire.com/?jomb2wzwmmk winimage itself is pretty easy in handling so I'll only describe briefly a way how to add widgets to the desired FW 1. run winimage 2. go to SystemFS/MediaSet and drag the unpacked widget pack http://www.mediafire.com/?jomb2wzwmmk 3. save file 4. download such modified ffs to your mobile using fastmultiloader visual instruction: attention! after loading modified .ffs file there is very high probability that the telephone will go through standard format procedure same as while loading new firmware so remember to backup anything you need remeber that everything you do you do at your own risk and neither I nor anyone form this forum takes no responsibility for any damage you may cause by using these procedures! n'joy regards, stn |
02-21-2009, 14:42 | #2 (permalink) |
Junior Member Join Date: Jan 2009
Member: 958086 Status: Offline Thanks Meter: 0 | Thanks to me for finding it on a german forum! You can remove the images no problems..but the stupid screen savre still displays the same pictures...ARGH not tried to do a widget with it yet :-) |
02-21-2009, 15:48 | #3 (permalink) |
Member: 653932 Status: Offline Thanks Meter: 63 | as a matter of fact, I knew about winimage a bit earlier, it started on a russian forums, my friend mentioned it to me, when it comes to images as I wrote, not all of them are in ffs, some are in rc1 I'm especially curious about widgets, I don't have this phone myself so I couldn't check it, in the package you have 27 widgets regards |
02-21-2009, 17:21 | #5 (permalink) | ||
Member: 653932 Status: Offline Thanks Meter: 63 | Quote:
and no, you can't download it from phone, you have to uplaod a totally new firmware on your phone.. read about in the other guides that are here in this section of gsmhosting forum and don't ask here how to do it, it's really all written patient and carefull reading is the best solution to all of the problems.. | ||
02-24-2009, 16:52 | #7 (permalink) |
Member: 951015 Status: Offline Thanks Meter: 3 | It's a bit more complicated than that. Here's how to actually do it. 1. Open WinImage, and click on Open Folder- icon. Browse to the firmware folder you want to modify and open the FFS file. (Note that WinImage is searching for .bin- files by default, so change that to "all files".) 2. Go to SystemFS -> Mediaset -> Widget 3. Drag the widgets you want to add to this folder. 4. Save. 5. Go to SystemFS -> User -> WidgetDefault.ini 6. Open WidgetDefault.ini 7. Either change the amount of widgets in the text file (.ini) or change the titles of default widgets to correspond the ones you just dragged to Widget-folder. 8. Save the text file you just modified to Desktop as "WidgetDefault.ini" and drag it to the SystemFS/User-folder, select YES to overwrite the old file. 9. Save. 10. Do a firmware flash with the FFS. Should work Last edited by idkhannes; 02-24-2009 at 16:57. |
02-24-2009, 17:29 | #8 (permalink) | |
Member: 951015 Status: Offline Thanks Meter: 3 | Quote:
2. Yes, you can change between firmwares as much as you want. Not that there's much difference between them. Some ridiculous menu colors and font types and that's it. I really regret ever getting this phone. It's miles behind Nokia. | |
02-26-2009, 13:10 | #14 (permalink) |
Junior Member Join Date: Feb 2009
Member: 981219 Status: Offline Thanks Meter: 0 | One more thing You refer to SystemFS -> User -> WidgetDefault.ini.. I cant find that in F48HCAHK2 or F48FXEIA3 for that matter.. Is it only a specific firmware you can add these widgets to? |
Software for Removing unnecessary files | d_t_e | Nokia Multimedia | 2 | 04-22-2009 08:09 |
How to install new version 5.0.5 with AVG antivirus installed! | The Dog | NSPRO | 4 | 01-23-2009 02:11 |
Nec 343i delete locked files | Jimbolino | NEC | 0 | 04-07-2006 02:16 |
Delete sys files? | Burtie | Sony Ericsson | 2 | 10-08-2005 23:30 |
7250i cable scheme, new soft, delete old soft | andyms2003 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 08-02-2004 14:52 |
