Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 11-24-2008, 21:20   #61 (permalink)
Member: 908929
I never worked with games on mobile phones etc, where do I have to enter that code in step 13,14 and 15? Do you need internet for that? I hope someone can help me.
Old 11-26-2008, 16:44   #62 (permalink)
Member: 908929
And I don't see any game, I installed Tkfileexplorer; after that I did al the steps you said. But when I look in my games folder, there's no game!Except that everthing works fine.
Old 11-30-2008, 13:40   #63 (permalink)
Member: 908929
Okay everthing works fine now thanks!
Old 12-10-2008, 08:43   #64 (permalink)
Member: 889852
thanks a trillion senseme..... it worked at last.. yuhuuuuuuuuuuu
Old 12-16-2008, 20:45   #65 (permalink)
Member: 912963
Thanks.
But I am stuck on 4, I don't seem to have "TkFileExplorer_2.2.exe".
edit: Dw I accidentally without noticing deleted it after I extracted :$ lmao
Old 12-18-2008, 15:09   #66 (permalink)
Member: 927067
Unbelievably, I cant get the fricking thing to recognise my phone. I install the driver, attach the phone (which mode do I need to be in? PC suite? Media etc...) and no message appears. Then I open the TKFileExplorer and the COM option is blank.
This question has probably been asked previously so excuse my idiocy - and thanks in advance for any help.
Old 12-18-2008, 17:12   #67 (permalink)
Member: 912963
Normal, PC Suite mode.
Old 12-30-2008, 17:05   #68 (permalink)
Member: 925915
Thanks Meter: 3
Thumbs up Install without WAP, FREE downloads!
Hi there,
on my site you'll find many tutorials, hints especially for Samsung phones! Also the newest Firmware F480XEHL1
in addition there are many java games & apps & pc-tools for FREE download!!
http://www.handysoft.info
Old 01-01-2009, 09:45   #69 (permalink)
Member: 936363
Originally Posted by sensesme View Post
  1. Download Driver & File Explorer.
  2. Uncompress SAMSUNG_Composite_USB_Driver_4_34_WHQL.zip and execute Setup.exe.
  3. Connect F480 to PC. First time you should be prompted with a 'device installed and ready' message.
  4. Execute TkFileExplorer_2.2.exe
  5. Go to Settings - COM.
  6. Scroll down Port window: You should get just one COMxx option. Choose it and press OK.
  7. Go to File - Connect. You should get the F480 File System Tree at TkFileExplorer bottom half side.
  8. Go to /Exe/Java/Games
  9. Create a New Folder for your game
  10. At TkFileExplorer PC upper side select game JAD/JAR files and copy to F480 created folder using drag&drop or right button menu Download option.
  11. Repeat steps 9 & 10 for all games you want to install at a time.
  12. Disconnect USB cable
  13. Dial *#6984125*#
  14. Go to Internals (Master Key: *#9072641*#)
  15. Go to Storage Settings and select Update Java DB
Enjoy! ...and save money!
NOTE 1:
You do not need to change Samsung USB mode to Qualcomm. Leave it at its default Samsung mode (if you do not understand this just do nothing )
NOTE 2:
Once driver is installed, Samsung PC Studio 3 still works.
SOURCE:
http://www.forummobiles.com/index.ph...=160797&st=896
Hi
When I click File > Connect, I've got an error msg which says WARNING: Unable to open specified port. Please try again.
What should I do?
Thanks!
Old 01-01-2009, 12:03   #70 (permalink)
mistahk's Avatar
Member: 653932
Thanks Meter: 63
repeat the procedure and check everything twice if you didn't make any mistakes, if ok, put cable into other usb port and try again
Old 01-01-2009, 14:28   #71 (permalink)
Member: 671225
Hi,
How do I get to Storage Settings?
In the admin menu I go to inernals and I can't find ANYTHING about storage settings... any ideas?
Old 01-01-2009, 15:44   #72 (permalink)
mistahk's Avatar
Member: 653932
Thanks Meter: 63
in z400 it's number 7 in internals
Old 01-04-2009, 05:59   #73 (permalink)
Member: 936363
Hi I repeated the procedure and tried different usb port.. the settings changed from COM16 to COM17 but I still got the same error msg. What should I do?
Thanks.
Old 01-04-2009, 13:15   #74 (permalink)
Member: 671225
Hi,
Can you use TkFileExplorer to remove the factory installed ringtones? I really hate that they show up in the music player and I neveruse them so is it possible to delete them?
Thanks
Old 01-05-2009, 05:56   #75 (permalink)
Member: 861971
Thanks Meter: 21
Originally Posted by cheerup347 View Post
Hi,
Thanks
I donīt know if you can remove the ringtones... but I tried to delete the factory wallpapers with the TkFileExplorer and it could not be deleted and also could not add pictures to that folder... So i guess u cannot delete anything that comes locked.
Free Video Tutorial : How to Update Genie Universal Firmware & Software fonefun Genie Universal 0 02-12-2010 21:30
Hardware & software Teacher/all Video and other Tutorials GSM-DOCTOR GSM Mobile Links 11 02-22-2009 14:28
Software/App/Game install without hotsync, How to Dashar PalmOS /HP and others 12 12-19-2008 21:03
-= Samsung E570 java install tutorial =- amonev Samsung Media, Games, Ringtones 0 11-18-2007 13:47
java soft by wap scurt Java, iOS, Android, Symbian development 1 06-10-2003 17:57
Page generated in 0.25423 seconds with 10 queries
