-   QUALCOMM Models (3G) (http://forum.gsmhosting.com/vbb/f352/)
-   -   F480 Java install without wap. Tutorial & software (http://forum.gsmhosting.com/vbb/f352/f480-java-install-without-wap-tutorial-software-609664/)
sensesme 10-12-2008 11:05
  1. Download Driver & File Explorer.
  2. Uncompress SAMSUNG_Composite_USB_Driver_4_34_WHQL.zip and execute Setup.exe.
  3. Connect F480 to PC. First time you should be prompted with a 'device installed and ready' message.
  4. Execute TkFileExplorer_2.2.exe
  5. Go to Settings - COM.
  6. Scroll down Port window: You should get just one COMxx option. Choose it and press OK.
  7. Go to File - Connect. You should get the F480 File System Tree at TkFileExplorer bottom half side.
  8. Go to /Exe/Java/Games
  9. Create a New Folder for your game
  10. At TkFileExplorer PC upper side select game JAD/JAR files and copy to F480 created folder using drag&drop or right button menu Download option.
  11. Repeat steps 9 & 10 for all games you want to install at a time.
  12. Disconnect USB cable
  13. Dial *#6984125*#
  14. Go to Internals (Master Key: *#9072641*#)
  15. Go to Storage Settings and select Update Java DB
Enjoy! ...and save money! ;)
NOTE 1:
You do not need to change Samsung USB mode to Qualcomm. Leave it at its default Samsung mode (if you do not understand this just do nothing :))
NOTE 2:
Once driver is installed, Samsung PC Studio 3 still works.
SOURCE:
http://www.forummobiles.com/index.ph...=160797&st=896
sensesme 10-12-2008 11:30
After executing Sansung PC Studio 3 I needed to restart my F480 to have TkFileExplorer working again. Consider this if you get some connect problem.
sensesme 10-12-2008 12:01
Other interesting thing:
TkFileExplorer allowed me to delete the 'built-in' game Photo Puzzle whitch is locked at F480 and cames inside folder /Exe/Java/Locked Games
WARNING:
Be careful with TkFileExplorer delete option!
it is a one-touch action!, it do not ask for confirmation.
mani444u 10-12-2008 23:37
i just tried it and eveything was successful but afetr i have updated it and i go to the games menu there is no game over there, where do i go to play the just insatlled game
mani444u 10-12-2008 23:40
do you thimk i should have installed it in the locked games folder
mani444u 10-12-2008 23:49
and yes i used the bejeweled no bar from the folder made by other members
sensesme 10-13-2008 09:25
I just repeated the procedure for the game Bejeweled you said and everything works for me.
Attached a screenshot of TkFileExplorer about files location:
http://img293.imageshack.us/img293/4...eledlx5.th.jpghttp://img293.imageshack.us/images/thpix.gif
mani444u 10-13-2008 11:24
i see, i noticed that you have a jad file in that folder can you tell me whee did you get that jad file from because i downloaded it and there was only a jar file, i am sure this is the reason
by the way i was so excited i forgot to thank you for the work
mistahk 10-13-2008 11:49
so finaly someone found/made software that sees those damn folders, nice work, [;
and whatsmore I can see it's old samsung's software, lol :>
mani444u 10-13-2008 11:52
i just installed my first game although it hangs but its a start
mistahk 10-13-2008 12:03
@mani444u: so click thanks on sensesme's first post if you realy want to thank to him
@sensesme: hope you won't mind if I translate it on our forum [samsung-mobile.pl] for Polish users [of course giving the reference links] [;
regards
mistahk 10-13-2008 12:33
in samsung you need both .jar and .jad files to install game at all, look for jadmaker on the Net
sensesme 10-13-2008 12:36
regards
Of course, feel free.
You can also see the information source at opening post.
sensesme 10-13-2008 12:42
Additonally we also got a nice F480 File Explorer that can be useful for a lot more things :D
mistahk 10-13-2008 12:51
yep, and it works fine with my, z400 too [; probalby a solution to all qualcomm phones, unless someone from samsung is reading this, so next models they change something :>
Page generated in 0.27966 seconds with 5 queries
