Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 10-17-2008, 02:40   #16 (permalink)
Member: 870970
Hallo guys! Please help!!! I just bought a F480 from Voda and the code for internals menu (*#6984125*#) doesn't work. Other codes work just fine!!!
Any ideas?????
Old 10-17-2008, 10:02   #17 (permalink)
Member: 877519
Any ideas?????
had the same issue my friend .. flashed the latest firmware first and it all worked fine after that. the codes worked like a charm
Old 10-17-2008, 16:19   #18 (permalink)
mistahk's Avatar
Member: 653932
Thanks Meter: 63
idea is that i would need to get that firmware then i could tell you what code it has, codes are firmware dependable, e.g. i'd changed all codes to *#00* in my z400 mod
Old 10-17-2008, 16:41   #19 (permalink)
Member: 457882
Thanks Meter: 9
thanx it works great its just i still get the little bar at the bottom??
Old 10-17-2008, 17:28   #20 (permalink)
Member: 870970
I was going to flash but again i bought it 2 days ago and i thought i had the new one. Is there a way to see what firmware i have right now? And can you give me the link to how to flash??? Thanks again for helping a greek guy out!!!
Old 10-17-2008, 17:55   #21 (permalink)
Member: 844641
Thanks Meter: 53
How to install Java games to F480?
Old 10-17-2008, 18:04   #22 (permalink)
Member: 844641
Thanks Meter: 53
Software version, dial:
*#1234#
Firmware flash procedure:
GUIDE: How to flash your F480 Tocco
Use just first post directions, it works great.
If you cannot see first post picture use post #64 picture.
Old 10-18-2008, 12:48   #23 (permalink)
Member: 878969
Smile
Thank you very much sensesme for sharing this tutorial. I have trying to download games into my samsung sgh z 170 for 5 months using many methods I read in many forums but none have worked on my cellphone. I was already in the point of giving up when I come across with your tutorial. Thanks for sharing this tutorial. It works perfectly on my samsung sgh z 170. Your the ONE!
Old 10-18-2008, 14:23   #24 (permalink)
Member: 878969
Cool
My phone is sgh z 170. When I drag the the jar and jad files from the desktop of my computer to the window of TkFileExplorer under phone as I usually do with samsung PC studio, it was not downloaded. So I open the Local Lisk (C at the upper left side window of TkFileExplorer, and under Drive D I open desktop. However, the jar and jad files were not there. No jar/jar files to download! So I first open samsung PC studio and from the desktop of my computer I drag the jar/jad files into the "Other Files" and put them in a new folder then close the samsung PC studio. After restarting my phone, I open TkFileExplorer. From the phone window of TkFileExplorer I open 'media' then 'Other Files', and then I drag the jad/jar file folder into the Local Disk (C at the upper left side of TkFileExplorer window. After transferring the folder I open 'Exe' then Java and then I drag the jad/jar folder from the local disk back into 'Java'. Under the the File Menu I click 'disconnect'. I then enter the codes into my phone and under Storage Settings I Update media database, Update Java DB, Update application database and Create Ax Dat File. When I returned to the 'Games and more' under my phone, the game was already installed!!! Thanks to Sensesme.......!!!
Old 10-18-2008, 16:30   #25 (permalink)
Member: 844641
Thanks Meter: 53
This is a confirmation about what user Mistahk said at post #15:
Originally Posted by mistahk View Post
yep, and it works fine with my, z400 too [; probalby a solution to all qualcomm phones, unless someone from samsung is reading this, so next models they change something :>
Old 10-19-2008, 13:15   #26 (permalink)
Member: 870970
*sensesme* you are the man!!!!! Everything worked like a charm!!!!! Thank you!!!!
Old 10-21-2008, 10:14   #27 (permalink)
Member: 868404
can u guys tell me a site with qualcomm drivers? i have samsung f490. thanks
Old 10-21-2008, 12:41   #28 (permalink)
Member: 868404
i've fixed out..it works fine now and games are installed..there's only one problem..some games do not work so i wanna delete them and the delete function does not work...it says erorr:unable to delete the specified files and folders...plz help
Old 10-21-2008, 13:51   #29 (permalink)
Member: 844641
Thanks Meter: 53
It really seems a driver problem.
I do not have any problem deleting files in my F480, including Samsung ROM installed files like game PhotoPuzzle.
At first post last line you have the source of data, follow that link maybe you find something...
Old 10-21-2008, 17:04   #30 (permalink)
Member: 881602
May i know why i tired till step 6 (Scroll down Port window: You should get just one COMxx option. Choose it and press OK.)
My Port window is blank did not have COMxx option? Please advise!!!
Free Video Tutorial : How to Update Genie Universal Firmware & Software fonefun Genie Universal 0 02-12-2010 21:30
Hardware & software Teacher/all Video and other Tutorials GSM-DOCTOR GSM Mobile Links 11 02-22-2009 14:28
Software/App/Game install without hotsync, How to Dashar PalmOS /HP and others 12 12-19-2008 21:03
-= Samsung E570 java install tutorial =- amonev Samsung Media, Games, Ringtones 0 11-18-2007 13:47
java soft by wap scurt Java, iOS, Android, Symbian development 1 06-10-2003 18:57
Page generated in 0.39687 seconds with 8 queries
