QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
08-06-2005, 19:31 | #1 (permalink) |
Insane Poster Join Date: Dec 2004 Age: 44
Member: 95076 Status: Offline Thanks Meter: 1 | FREE complete unlock solution for Samsung SGH-Z500! What do you need? Software: WinIMEI 1.16, USB Drivers, EasyStudio (Optional but highly recommended). Links to software are at the end of this post. Hardware: Computer running Win9x/NT/2000/XP, 1x Serial COM Port, 1x USB Port, 1x USB Data Link Cable(PCB429USE). 1. Extract all RAR archives into own empty folder. 2. Install the drivers for the phone. You only need to install the drivers from the folder Samsung CDMA USB Driver don’t mind the folder Samsung Mobile USB Driver. 3. Connect the phone to the computer using the USB Data Link Cable. If it asks you about drivers just choose to install the driver from a specific location and point it to the Samsung CDMA USB Driver folder or its subfolder. 4. Now run the setup for EasyStudio and install it like any other application. Check what COM port the Samsung CDMA USB Driver has in the control panel under Phone and Modem options. If the port is higher than 10 force it to port 9 or less. Then go to the Settings Menu and choose Phone Monitor Settings. Look in the COM ports tab and check that the port with the CDMA USB Driver is enabled then press OK. Now it should find the phone. Choose File Manager to the left and then press backup on the top right then choose backup media. This is because WinIMEI might corrupt files. If the phone is not frozen a better option might be to just read the codes with WinIMEI and then enter them manually to unlock it without risk for file system corruption. (Skip this step if you enter codes manually). 5. Now connect the DB9 (partial) loopback connector to COM1. Look at the included picture for info on how to make one. All you have to do is short pin 2 with pin 3 as shown on the picture (look at the red line) and the COM1 port of your computer will now work as a (partial) loopback UART. This is required for WinIMEI to work. 6. Start WinIMEI (QIWS_V1.16(Service)_041011.exe) and on the first screen choose the USB COM port, leave the rest as is and press OK. On the next screen press UNLOCK. If everything went ok your phone is now unlocked! Or if you want to enter the unlock codes manually choose Read Settings instead. 7. Restore your media files with EasyStudio. (If you didn’t press UNLOCK you can skip this step). 8. Done! FAQ: Q: Why should i make sure the port in WinIMEI is set to 9 or less? A: Serial ports in Windows are considered to be standard physical devices, that is why you should open any device in the following way: "\\.\COM10". Using the shortened name ("COM1" or "COM3") you can open only first 9 serial ports. More information on this issue can be found in MSDN. Q: I can't do anything and it says "Phone Freeze", can I unlock this? A: Yes! It will unfreeze and unlock your phone! Here are the files: -------------------------------------------------------------------------- http://rapidshare.de/files/3698773/E...part1.rar.html http://rapidshare.de/files/3699026/E...part2.rar.html http://rapidshare.de/files/3699258/Z105V1.16.rar.html http://org.downloadcenter.samsung.co..._USBDriver.exe |
08-06-2005, 19:53 | #2 (permalink) |
No Life Poster Join Date: Dec 2000 Location: CHANDIGARH - INDIA Age: 59
Member: 2822 Status: Offline Thanks Meter: 152 | Thanks 4 the info and soft but only one request ols upload files on some other free server like megadownload as i always get ereers with rapidshare something like IP Add errrers. Thanks wbr Ashwani Gaur if possible u can send at:- [email protected] |
08-09-2005, 02:31 | #3 (permalink) |
Member: 95076 Status: Offline Thanks Meter: 1 | Also go ahead and try this: Power on your phone (Models Z105, Z107v, Z500, Z500V, etc.......) 1- Enter code *7465625*28782# without a sim in the phone 2- Phone will display "Auto Subset Lock: Activated!" 3- Enter code *7465625*28638# without a sim again 3- Phone will display "Auto Network Lock: Activated!" 4- Now insert the sim and enjoy! Phone is Unlocked! (NOTE: When you change sim to other operator repeat this process to unlock it for that operator also) I found this in another thread. All credits for the solution to Morfeus of the FuriousTeam! I myself haven't got a locked Z500 so i cannot try this. But other people confirmed this as working. I'd like to hear more results on this! I also found a list of service codes. I guess you could use some of them to enter your unlock codes manually(that you read out with WinIMEI). Check Versions of h/w s/w f/w: *#1111# S/W Version *#1234# Firmware Version *#2222# H/W Version *#8999*8376263# All Versions Together Locks: *#7465625# = Check Locks *7465625*638*Code# = Enables Network Lock #7465625*638*Code# = Disables Network Lock *7465625*782*Code# = Enables Subset Lock #7465625*782*Code# = Disables Subset Lock *7465625*77*Code# = Enables SP Lock #7465625*77*Code# = Disables SP Lock *7465625*27*Code# = Enables CP Lock #7465625*27*Code# = Disables CP Lock *7465625*746*Code# = Enables SIM Lock #7465625*746*Code# = Disables SIM Lock *7465625*228# = Activa lock ON #7465625*228# = Activa lock OFF *7465625*28638# = Auto Network Lock ON #7465625*28638# = Auto Network Lock OFF *7465625*28782# = Auto Subset Lock ON #7465625*28782# = Auto Subset Lock OFF *7465625*2877# = Auto SP Lock ON #7465625*2877# = Auto SP Lock OFF *7465625*2827# = Auto CP Lock ON #7465625*2827# = Auto CP Lock OFF *7465625*28746# = Auto SIM Lock ON #7465625*28746# = Auto SIM Lock OFF Last edited by reefer45; 08-09-2005 at 03:12. |
08-09-2005, 09:21 | #7 (permalink) |
Major Poster Join Date: Jul 2005 Age: 44
Member: 161452 Status: Offline Thanks Meter: 0 | Excellent post reefer45, I already unlocked my Z500 with the last thread you made. I'd just like to add something that may be easier for some people and worked for me. When making the DB9 connector instead of adding a partial connector, just get a normal serial cable, plug one end in to your pc as normal. On the other end you need to short pins 2 and 3 again, however this time it's not the [ 1 (2 3) 4 5 ] for the top line, but [ 5 4 (3 2) 1 ]. Just do it with a paperclip and it will work fine! |
08-09-2005, 09:56 | #8 (permalink) |
Member: 95076 Status: Offline Thanks Meter: 1 | Here are the files at another mirror for those that rapidshare isn't working well for! Easy Studio Part 1 of 2 http://www.savefile.com/files/2630324 Easy Studio Part 2 of 2 http://www.savefile.com/files/5195451 WinIMEI 1.16 http://www.savefile.com/files/5790105 |
08-09-2005, 10:05 | #9 (permalink) |
Member: 95076 Status: Offline Thanks Meter: 1 | alchemyst: Any suggestions are welcome! I see a forum as a place for people to work together and to share theird knowledge. Unlike some other people who see it as a place to make money off of people. everyone: Thank you for writing that you appreciate my post! A simple thank you is enough to see that people appreciate the time i've spent writing the guide. I will surely try to contribute in more ways. If anyone has an unbranded flash with swedish lang for the z500 please help me out! |
08-09-2005, 10:19 | #11 (permalink) |
Freak Poster Join Date: May 2004 Age: 58
Member: 65419 Status: Offline Thanks Meter: 4 | thank you very much mate for this new unlocking procedure it will be quite easy now to unlock have done unlocking z105 using winimei before. new procedure is much easier. brgds meneleo |
08-09-2005, 16:34 | #12 (permalink) | |
Member: 161452 Status: Offline Thanks Meter: 0 | Quote:
08-10-2005, 11:41 | #13 (permalink) |
Registered User Join Date: Dec 2002 Location: The Netherlands Age: 41
Member: 19168 Status: Offline Thanks Meter: 55 | I have tried the winimei 1.16 with Z500, it works perfect,but when I try to read teh settings on Z500V, it gives error on reading the MePersonalisation. Anyone can help me in this case? thank you in advance |
08-11-2005, 01:08 | #14 (permalink) |
Member: 95076 Status: Offline Thanks Meter: 1 | Have you tried using the "trick" with the codes instead of WinIMEI? Otherwise try and chose the Z105 T or U model to read settings. And last of all you could try to press UNLOCK even though it has trouble reading some setting. But of course there is a risk involved. But if the phone is new it can always be returned to a repair shop if things would go bad. update: i read on another forum that Z500V's should work using this same method and WinIMEI version using UNLOCK. Last edited by reefer45; 08-11-2005 at 21:06. |
08-11-2005, 21:23 | #15 (permalink) | |
I need solution for Samsung SGH 500 Phonecode | MaRiN | VLSI, Conexant, Skyworks and Old Models | 8 | 11-06-2012 20:08 |
Unlock solution for Samsung SGH-P510 | dali73 | Trident/AGERE Platform | 1 | 07-30-2006 17:01 |
Unlock code for Samsung SGH-307 | nesbpserv | Phone Unlocking Codes & Maps | 0 | 03-20-2004 05:33 |
I need unlock solution for Samsung SGH N100 | MaRiN | VLSI, Conexant, Skyworks and Old Models | 0 | 07-26-2001 00:54 |
Need solution for Samsung sgh-800 | hungpd | Various | 0 | 07-11-2000 16:21 |
