Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 08-12-2005, 01:35   #16 (permalink)
Registered User
to_deal_with's Avatar
Member: 19168
Thanks Meter: 55
thanx,
I will try again
Old 08-12-2005, 06:42   #17 (permalink)
dhru_21's Avatar
Member: 155820
Thanks Meter: 60
.............Thnx.............
Old 08-13-2005, 19:09   #18 (permalink)
riadh_tn's Avatar
Member: 21553
Sonork: 100.114141
Thanks Meter: 220
also for the cable we can use normal cable for LG 3G is the same and work pêrfect
Old 08-15-2005, 09:52   #19 (permalink)
Member: 170643
Hey,
I have heard that when using the unlocking tools/procedures it actually causes a fault in the phone. I have been told that certain unlocking methods for the Samsung Z500 cause the loud speaker to malfunction and ringtones discontinue to work. Is this true in this case? Has anyone tried and had this problem?
Old 08-16-2005, 03:21   #20 (permalink)
Member: 171139
Originally Posted by Ly Lam
Hey,
I also read this would happen,that you would loose the loudspeaker and the sound of the ringstones, as the program is for Z105 and not for Z500.
Please say something about this.
Thanks
Old 08-16-2005, 04:38   #21 (permalink)
Member: 77923
Thanks Meter: 4
thanks man good work
Old 08-16-2005, 20:41   #22 (permalink)
Member: 171136
Is this codes valid for Z300?
Anyone have tested it?
Does it changes the IMEI? This is my principal concerning because of the waranty.
Any help...
Other sugestions accepted for unlock Z300 without changing IMEI.
Old 08-18-2005, 01:29   #23 (permalink)
Member: 171139
I need help. I can't unlock Z-500. I'm using a DB9 serial cable with a female to male connector, and have shorted the pins. I plug the cable to COM 1, and the Samsung CMDA Modem is on COM 4. Then I start WinIMEI, and I can't change USB COM port. Then I can't read settings or unlock using either Z-105, Z-105T or Z-105U.´
Please help me.
Old 08-18-2005, 08:58   #24 (permalink)
patric's Avatar
Member: 8228
Thanks Meter: 132
the good solution is to use the data cable with special pinout using the soft , it will unlock the phone to all operator
Old 08-18-2005, 11:43   #25 (permalink)
Member: 171139
"the data cable with special pinout using the soft " which cable?
Old 08-18-2005, 12:44   #26 (permalink)
Member: 171139
i've succeed to unlock my samsung z-500, the problem was with the com door of the samsung modem, i changed it to com 7 and it worked perfectly. thanks to all
Old 08-18-2005, 14:47   #27 (permalink)
Member: 171136
1- Enter code *7465625*28782# without a sim in the phone
2- Phone will display "Auto Subset Lock: Activated!"
3- Enter code *7465625*28638# without a sim again
3- Phone will display "Auto Network Lock: Activated!"
4- Now insert the sim and enjoy! Phone is Unlocked!
And i enjoy it!!!
It works!
On my phone the subset lock was of so i skip 1 and 2.
I just try the 3rd and after i insert the new sim...it works fine...no changes at all on the phone...just the permission to a new network.
Free and simple....now the unbranded firmware...(where it is for portugal? Mine actual is Z300BFEF2 branded by Optimus!)!
Old 08-19-2005, 14:07   #28 (permalink)
Member: 170643
Hey,
So if i follow the steps from 1-4 the phone will unlock and will not play up? The speaker will be normal? Or do I need to adjust the settings?
Old 08-19-2005, 14:23   #29 (permalink)
OvidelGSM's Avatar
Member: 103544
Sonork: 100.75677
Thanks Meter: 155
is not working for me
Old 08-19-2005, 18:05   #30 (permalink)
Member: 172324
it worked 4 me and im now usin an o2 sim card in it- but cant get the gprs/wap thing to work-ne1 ne ideas???
I need solution for Samsung SGH 500 Phonecode MaRiN VLSI, Conexant, Skyworks and Old Models 8 11-06-2012 20:08
Unlock solution for Samsung SGH-P510 dali73 Trident/AGERE Platform 1 07-30-2006 18:01
Unlock code for Samsung SGH-307 nesbpserv Phone Unlocking Codes & Maps 0 03-20-2004 05:33
I need unlock solution for Samsung SGH N100 MaRiN VLSI, Conexant, Skyworks and Old Models 0 07-26-2001 01:54
Need solution for Samsung sgh-800 hungpd Various 0 07-11-2000 17:21
Page generated in 0.45043 seconds with 9 queries
