QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
02-14-2006, 09:55 | #94 (permalink) | |
Junior Member Join Date: Feb 2006
Member: 228984 Status: Offline Thanks Meter: 0 | Quote:
02-16-2006, 22:37 | #96 (permalink) |
Member: 233800 Status: Offline Thanks Meter: 0 | Hi all, None of the shown options are working for my (Dutch Vodafone) Z500V. Even worse: I just managed to "freeze" the phone, so no simcard is working anymore. I first tried the code thing (*7465625*28782# etc.) which didn't work. After that I tried the "UMTS IMEI Program.exe", ofcourse with the appropriate USB drivers. But how should I get this program working? When it starts it says "Can't open COM1" and after that I can choose the model and buyer, but I can't change anything regarding the used port. When I check up at modems the CDMA Samsung modem is at COM8. How can I tell the UMTS IMEI Program which COM port to look at? Also, I am using the USB cable as enclosed in the Z500V package. Is that one ok? Thanks so much. |
02-16-2006, 23:25 | #97 (permalink) | |
Member: 233423 Status: Offline Thanks Meter: 0 | Quote:
i'm going to talk Dutch right now...... Heb je wel achter je computer een ijzer draadje tegen pin 2 & 3 gezet? I think you can't change the standard port in the program, the program on my computer used com2 and so i changed it to that port and it worked Maybe you can try this way: http://forum.gsmhosting.com/vbb/showthread.php?t=239111 That workt for me perfectly yesterday! otherwise...PM maar ofzo | |
02-18-2006, 11:28 | #98 (permalink) |
Junior Member Join Date: Dec 2005
Member: 204663 Status: Offline Thanks Meter: 0 | help please!!!!!! i get phone is in use!!!!!!!! error hi there!! when i run easystudio and do as you say i get the following!!!! "phone is in use easystudio can be used only when your phone is in idle state. please close all aplications on your phone." all i have done is plug in the cable and the program switched on the phone on the phone screen i have the usual message PHONE FREEZE sim unavailable please inquire to the service provider arrrrrrrrrrrggggggggggg!!!!!!!!!!!!!!!!! i canot get this to work!!! pleasse help me guys!!! thanks |
02-20-2006, 17:12 | #99 (permalink) |
Junior Member Join Date: Jun 2005 Age: 47
Member: 152856 Status: Offline Thanks Meter: 0 | samsung z500 [QUOTE=reefer45]Also go ahead and try this: Power on your phone (Models Z105, Z107v, Z500, Z500V, etc.......) 1- Enter code *7465625*28782# without a sim in the phone 2- Phone will display "Auto Subset Lock: Activated!" 3- Enter code *7465625*28638# without a sim again 3- Phone will display "Auto Network Lock: Activated!" 4- Now insert the sim and enjoy! Phone is Unlocked! (NOTE: When you change sim to other operator repeat this process to unlock it for that operator also) I found this in another thread. All credits for the solution to Morfeus of the FuriousTeam! I myself haven't got a locked Z500 so i cannot try this. But other people confirmed this as working. I'd like to hear more results on this! I also found a list of service codes. I guess you could use some of them to enter your unlock codes manually(that you read out with WinIMEI). Check Versions of h/w s/w f/w: *#1111# S/W Version *#1234# Firmware Version *#2222# H/W Version *#8999*8376263# All Versions Together Locks: *#7465625# = Check Locks *7465625*638*Code# = Enables Network Lock #7465625*638*Code# = Disables Network Lock *7465625*782*Code# = Enables Subset Lock #7465625*782*Code# = Disables Subset Lock *7465625*77*Code# = Enables SP Lock #7465625*77*Code# = Disables SP Lock *7465625*27*Code# = Enables CP Lock #7465625*27*Code# = Disables CP Lock *7465625*746*Code# = Enables SIM Lock #7465625*746*Code# = Disables SIM Lock *7465625*228# = Activa lock ON #7465625*228# = Activa lock OFF *7465625*28638# = Auto Network Lock ON #7465625*28638# = Auto Network Lock OFF *7465625*28782# = Auto Subset Lock ON #7465625*28782# = Auto Subset Lock OFF *7465625*2877# = Auto SP Lock ON #7465625*2877# = Auto SP Lock OFF *7465625*2827# = Auto CP Lock ON #7465625*2827# = Auto CP Lock OFF *7465625*28746# = Auto SIM Lock ON #7465625*28746# = Auto SIM Lock OFF[/QUO Hello! I have a loocked samsung z500 and your solution worked perfect too. Thank you verry much.Kiss. |
02-21-2006, 12:17 | #100 (permalink) | |
Member: 231059 Status: Offline Thanks Meter: 1 | Quote:
The Following User Says Thank You to rsa84 For This Useful Post: |
03-09-2006, 08:35 | #101 (permalink) | |
Freak Poster Join Date: Jul 2004 Age: 45
Member: 72925 Status: Offline Thanks Meter: 2 | Quote:
03-09-2006, 18:25 | #102 (permalink) |
Junior Member Join Date: Mar 2006
Member: 242347 Status: Offline Thanks Meter: 0 | Hello, any can send me WinIMEI me to email [email protected] i need unlock my saumsung Z500v and i need all good programs Thanx all! You links not working |
I need solution for Samsung SGH 500 Phonecode | MaRiN | VLSI, Conexant, Skyworks and Old Models | 8 | 11-06-2012 20:08 |
Unlock solution for Samsung SGH-P510 | dali73 | Trident/AGERE Platform | 1 | 07-30-2006 17:01 |
Unlock code for Samsung SGH-307 | nesbpserv | Phone Unlocking Codes & Maps | 0 | 03-20-2004 05:33 |
I need unlock solution for Samsung SGH N100 | MaRiN | VLSI, Conexant, Skyworks and Old Models | 0 | 07-26-2001 00:54 |
Need solution for Samsung sgh-800 | hungpd | Various | 0 | 07-11-2000 16:21 |
