QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
12-31-2004, 02:36 | #32 (permalink) |
Junior Member Join Date: Dec 2004 Age: 48
Member: 100611 Status: Offline Thanks Meter: 0 | Very good i see you learn something with me!!! how to do it!! well done, and must work with the others phones models in same system of cable to unlock the phones lololooo All the best for you Happy new Year for ALL SHARK76 |
12-31-2004, 11:13 | #33 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 41
Member: 90734 Status: Offline Thanks Meter: 3 | Happy New Year to All Happy new year to all unlockers... Thank you skazi and Angelo for the good solution of the Z105. I have not tested all the Procedure, but I think it works, becasue I have make all the steps before with the cutting green wire and Unite the 2-3 pin to it, but I have not think about to remove the 2-3 pin cable again. I will post result when I test it. Happy New Year to all. Thamer SMA Sweden Mobilephone Accessories www.swedenmobile.com |
12-31-2004, 13:16 | #34 (permalink) |
Freak Poster Join Date: Dec 2001 Location: InnovateK
Member: 8012 Status: Offline Thanks Meter: 124 | There is no need to cut the green wire (D1) of USB cable , only need to connect COM 1 DB9 pin 2 (TX) and 3 (RX) together, or you can even use MBUS cable for this purpose . It works with no problem at least for me . Happy New Year for all :-) Portugal is with countries affect by the damn tsunami :-( |
01-02-2005, 18:45 | #35 (permalink) |
Registered User Join Date: Jul 2004 Location: nonthaburi thailand Age: 51
Member: 73464 Status: Offline Thanks Meter: 26 | PLEASE HELP i try all solution make USB nomal cable and connect DB9 PIN2-3 and green line to pin 2-3 DB9 i got error is ERROR DETECT USB POST TIMEOUT ! if i removed Green line and when com ok i got error is USB PORT FAIL pleaase help |
01-02-2005, 21:11 | #36 (permalink) | |
No Life Poster Join Date: Aug 2002 Location: Up North
Member: 14934 Status: Offline Thanks Meter: 79 | Quote:
WORKING!! http://www.gsmsweden.com/new_z105_unlock_interface.jpg | |
01-03-2005, 03:47 | #37 (permalink) | |
Junior Member Join Date: Dec 2004 Location: Caparica, Portugal Age: 38
Member: 101793 Status: Offline Thanks Meter: 0 | Quote:
The files that comes within the z105.rar file are pre-instalation drivers, attention to that... you sould install full drivers with the phone connected, after that run the start procedure. | |
01-03-2005, 05:37 | #38 (permalink) |
Member: 73464 Status: Offline Thanks Meter: 26 | thank but i try to reinstall driver agan then try still same problem and i try agan on 98 os it ok on USB port open but read imei ok but no show imei on textbox and read master lock fail are u useing on xp or 98 ? |
01-03-2005, 18:48 | #40 (permalink) | |
can someone else confirm that it have alot to do with the "USB PORT FAIL" error.. TO ALL: if you have "USB PORT FAIL" error change usb port manualy and write the result here =p | |
01-04-2005, 19:19 | #43 (permalink) | |
No Life Poster Join Date: Dec 2004
Member: 97600 Status: Offline Thanks Meter: 97 | Quote:
01-04-2005, 21:03 | #45 (permalink) | |
when i try to read it get read master control lock fail what am i doing wrong? any help would be helpfull thanks. my phone is not frozen its fully working i just want to unlock from vodafone uk Last edited by ringtons; 01-05-2005 at 19:39. | |
Martech Complete Solution All in One (TRICKS / SOLUTION / GUIDE) | The_Gorr | Martech CLIP / Box / Key | 22 | 05-16-2006 08:31 |
[NEED] Samsumg Z105 unlock solution | tneto | QUALCOMM Models (3G) | 0 | 11-30-2004 16:45 |
PLS Where can I get Free & Complete Cracked Wintesla with Most DLL's | dannyogolo | Nokia Multimedia | 3 | 10-29-2003 23:25 |
here is the complete solution for nokia2100 LRS13A1 flash | magnet | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-17-2003 11:33 |
