QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
02-17-2005, 14:18 | #61 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: Lisbon, Portugal Age: 47
Member: 69293 Status: Offline Thanks Meter: 19 | Quote:
I reformated my pc and Installed the Z105 drivers, It is working once again. | |
02-25-2005, 16:59 | #63 (permalink) | |
No Life Poster Join Date: Aug 2001 Location: P A K I S T A N _____________ Age: 40
Member: 5932 Status: Offline Thanks Meter: 1,694 | Quote:
Start Unlock the phone... Check Serial Communication with the phone. Wait ... Seial COM. - GOOD SUCCESS: DETECT USB PORT... Searching SAMSUNG Modem... USB Port Open Fail WHAT is the SOLUTION for the ABOVE Problem.. changed PC but problem is still the same.. What is the SOLUTION? THANKS and Regards, Abdul Wahab. | |
02-26-2005, 06:59 | #65 (permalink) | |
Drivers is INSTALLED.. if there any other way to install drivers let me know. br. A. Wahab. | |
02-26-2005, 12:41 | #66 (permalink) | |
Freak Poster Join Date: Aug 2003 Location: on earth Age: 56
Member: 36391 Status: Offline Thanks Meter: 0 | same prob with me regards celcom Quote:
02-26-2005, 19:36 | #67 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Austria-Velden Age: 29
Member: 14684 Status: Offline Thanks Meter: 60 | Search wich com port is emulated. ( Samsung modem ) is higher than 10, set it to 5 or 6. This works! And post resultat!! Sorry for my bad english |
03-11-2005, 02:36 | #72 (permalink) | |
No Life Poster Join Date: Jul 2002
Member: 13737 Status: Offline Sonork: 100.100725 Thanks Meter: 194 | Quote:
open and chage white and blue to <> and than connect powered fone with usb and install drivers include modem drivers than use db9 connector short 2-3 and make 1 wire (green ) and connect that wire with usb green wire during operation when detect com than detach that wire all shoud be ok | |
03-11-2005, 04:25 | #73 (permalink) |
Freak Poster Join Date: Dec 2001 Location: InnovateK
Member: 8012 Status: Offline Thanks Meter: 124 | USB port higher than 10 problem and ...... U all should start to understand a little better your OS REGISTRY , u can do so much things ...... If u have the USB modem assigned to a port higher than 10 just run REGISTRY editor and in FIND write "COM10" or 6,7,8,9,11 or 12 or .....value data , delete all the values that appear , in this way u donīt need to uninstall any sw or modemīs, and this is useful for other sw like Sharp, Nec...all the sw that uses USB emulation port connection and only have available from COM1 to COM10 to choose. U donīt need to connect any green wire, just install usb drivers, connect USB cable with phone ON, shunt pin2 and 3 from Serial COM1 run software , choose the correct MODEL and BUYER (for IMEI change select [00]OnlyIMEI ), than just do what u got to do! Drivers and software for Z105 work 100% with Z107 [at least for me ] hope itīs explicit enough..... see ya AngeloCruz |
03-11-2005, 18:58 | #75 (permalink) |
No Life Poster Join Date: Jan 2001 Location: France/Martinica/CPU Age: 45
Member: 3026 Status: Offline Sonork: 100.1602750 Thanks Meter: 102 | tested today Z107(with driver Z105) with modem comport<10 on 2 pc don't working with forcing com port perhap's try to change PC |
Martech Complete Solution All in One (TRICKS / SOLUTION / GUIDE) | The_Gorr | Martech CLIP / Box / Key | 22 | 05-16-2006 08:31 |
[NEED] Samsumg Z105 unlock solution | tneto | QUALCOMM Models (3G) | 0 | 11-30-2004 16:45 |
PLS Where can I get Free & Complete Cracked Wintesla with Most DLL's | dannyogolo | Nokia Multimedia | 3 | 10-29-2003 23:25 |
here is the complete solution for nokia2100 LRS13A1 flash | magnet | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-17-2003 11:33 |
