Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 03-12-2005, 11:45   #76 (permalink)
Member: 123293
Thanks Meter: 3
Originally Posted by Hologram
Hello, Some news on change IMEI on Z105?
Have you solved EMPTY CALDATE Error?
Thanks
Regards
press *#9998*324# then [2][2][5]
and enter 2004.09.18
Thats it
Old 03-12-2005, 22:02   #77 (permalink)
Member: 119294
Thats it
What does the CALDATE do?
Old 03-15-2005, 11:09   #78 (permalink)
Member: 91605
Thats it
I'm sorry, but ... this isn't problem....
Cal date are correctly set, but WinImei continue saing CALDATE error, and won't write imei. Any tips?
Regards
Old 03-15-2005, 16:26   #79 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,393
its not so easy to restore call date & rebuild IMEI.Winimei its not enagh to make that operations.U need much more.
Old 03-17-2005, 18:14   #80 (permalink)
Member: 28858
@Mods
I need the chinese flash file for the Z105u samsung 3g phone very badly, the phone had chinese language it in i tried to load french, now the phone only blinks, so can u pls post here or infom whr i can download it?
WBR
AE177
Old 04-18-2005, 22:36   #81 (permalink)
unlocker2000's Avatar
Member: 56387
Thanks Meter: 10
Unlock Method for Z105 works perfect with Z107, Thanks!!!
Old 04-19-2005, 18:37   #82 (permalink)
Member: 91605
What I need?
Just for Info, Have you pinout of that phone? or can you tell me where I can found it?
Thanks
Regards
Old 05-20-2005, 15:40   #83 (permalink)
Member: 145872
Someone has a software for flashing Z105 and make it no-brand?
Old 05-27-2005, 04:05   #84 (permalink)
Member: 148431
U dont lose IMEI if u use CORECT cable & CORECT software
I everyone.
Is the usb cable that came with the phone the right one? Is the "Qualcomm IMEI WRITE SYSTEM For Z105 (Advanced Service by ELCO)" the right one?
If i just unlock i won't loose the IMEI? Many people are saying they loose RF Cal Date and IMEI.
Sorry for the questions but just wanted to be sure before i try.
Thaks to everyone for the suport.
Old 05-27-2005, 15:45   #85 (permalink)
Member: 148431
Hi again. Forgot to say that i don't need to unlock the phone, i just want to remove the "Phone Freeze". Can anyone tell me if i will lose the IMEI using the software posted here, or the one modified by ELCO?
By the way, when unlocking the phone should it be done with or without the SIM?
Thanks
Old 05-27-2005, 19:03   #86 (permalink)
Member: 33320
Thanks Meter: 6
Originally Posted by D_only_1
I again. Forgot to say that i don't need to unlock the phone, i just want to remove the "Phone Freeze". Can anyone tell me if i will lose the IMEI using the software posted here, or the one modified by ELCO?
Thanks
I'm unlocking Z105 & Z107 without SIM
B.R.
Dusko
Old 05-27-2005, 23:23   #87 (permalink)
Member: 148431
It's done. My phone isn't frozen anymore Used the Qualcomm v1.16 and standard usb cable. No IMEI loss.
Thanks a lot.
Cheers
Old 06-02-2005, 11:23   #88 (permalink)
freedomizer's Avatar
Member: 123931
Originally Posted by forhike
yes that's correct after changing usb port manualy it works after first atempt,
can someone else confirm that it have alot to do with the "USB PORT FAIL" error..
TO ALL:
if you have "USB PORT FAIL" error change usb port manualy
and write the result here =p
I got sofar with this, but not sure where to change the USB port manually. Could you please specify?
Old 06-02-2005, 11:38   #89 (permalink)
Member: 123931
silly problem. SOLVED! Modem has to be on Com port under 10.
Old 06-02-2005, 12:41   #90 (permalink)
GSMARMOON's Avatar
Member: 90804
Thanks Meter: 46
z107?
pdf.FOR UR INFORMATION
Martech Complete Solution All in One (TRICKS / SOLUTION / GUIDE) The_Gorr Martech CLIP / Box / Key 22 05-16-2006 09:31
[NEED] Samsumg Z105 unlock solution tneto QUALCOMM Models (3G) 0 11-30-2004 16:45
PLS Where can I get Free & Complete Cracked Wintesla with Most DLL's dannyogolo Nokia Multimedia 3 10-29-2003 23:25
here is the complete solution for nokia2100 LRS13A1 flash magnet Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-17-2003 12:33
Page generated in 0.45320 seconds with 9 queries
