Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 03-05-2009, 22:56   #1 (permalink)
Member: 358893
Thanks Meter: 33
GUIDE: How to flash M8800 Pixon
OK this is the start and l hope that you all will consider and post any newer information.
First thing to always remember, is BACK UP YOUR PHONE, Pictures,wallpapers,music, and any contacts you have saved on your phone. I am not responsible for any damage to you, your phone, computer, or lost of data in this process. This is a guideline intended for professional technicians.
USE AT YOUR OWN RISK!!!
1. USB cable that came with your phone.
2. Samsung PC Studio 3 witch can be found here:
http://www.samsung.com/uk/support/d..._ia_cd=01011800
Install this software first, it contains the drivers for your phone, and has every thing you need for backup.
3. Multiloader v5,50 http://www.4shared.com/file/75565159...ader_V550.html
5. Newest unbrranded firmware http://www.megaupload.com/?d=B5CXDIOZ
-----------------------------Now you are ready to begin-----------------------------------
1. Make sure Samsung PC Studio is installed and communicates with your phone. And unpack the firmware in a folder you can easily find it.
2. Remove the Sim and MicroSD from your phone and replace the battery.
3. With the phone OFF connect the phone and computer with the USB cable.
4. While holding the no. 9 button on the phones key pad, tap the power button, the phone screen will come on black with a red stripe that says "Download" ( For Tocco and Pixon users : Hold down the "Volume -" button on the left side, and the "Camera" button on the right, then press the "Power" button = all three buttons need to be pressed together. Your phone should start up into a red\blue on black bootloader screen.)
5. Now run MultiLoader v5.33
6. Select the radio button that includes MSM6275/MSM6280.
7. Select Boot Change and Full Download.
8. Then click Boot, and select the boot files from the unpacked firmware folder.
9. Click the Amss, Rsrc1, and Rsrc2.
10. Then press the Factory FS tab, and select the appropriate files from the firmware folder also.
11. Select (Low).r2c NOT (Mid).r2c. (Phone may not restart if you select mid)
12. FOTA and ETC fields are left blank.
13. Click the Port Search button, it will find your phone and show the com port is ready.
14.Click the download button and be patient, this will take a few minutes to complete.
15.When it's finished, it will show "ok complete".
16.Unplug the phone from the USB cable, reinstall the sim, MicroSD, and power up the the phone.
17. Now with every thing complete, perform a hard reset by typing *2767*3855# into the hand set.
18. When the phone resets type *#1234# into your handset to check your new firmware ver.
The Following 27 Users Say Thank You to kronos1 For This Useful Post:
Old 03-05-2009, 22:59   #2 (permalink)
Member: 358893
Thanks Meter: 33
Not yet tested so if any one do this please tell us your results...
BE SURE TO BACK UP all data you may need later!
Old 03-06-2009, 23:35   #3 (permalink)
Member: 669037
It's working great and support most EU countries.
Old 03-07-2009, 09:02   #4 (permalink)
Member: 147039
Thanks Meter: 88
today reflashed 5 m8800 tested.
Old 03-07-2009, 10:35   #5 (permalink)
mistahk's Avatar
Member: 653932
Thanks Meter: 63
11. Select (Low).r2c NOT (Mid).r2c. (Phone may not restart if you select mid) - because? you know the difference or not?
17. Now with every thing complete, perform a hard reset by typing *2767*3855# into the hand set. - what for?
Old 03-07-2009, 15:02   #6 (permalink)
Member: 988844
Thanks Meter: 4
Is it possible to flash F480 with this firmware? Did anybody try to do this? What's the consequence? "freeze" "dead" or full operating?
Old 03-07-2009, 16:20   #7 (permalink)
Member: 358893
Thanks Meter: 33
NO THE TOCCO HAS DEFERENT FIRMWARE so ther is another theme in this forum with instructions for Tocco, it is no possible to import firmware of Pixon model into Tocco model..
Can any one please post what the improvements are with this newest firmware?'
The Following 2 Users Say Thank You to kronos1 For This Useful Post:
Old 03-07-2009, 19:01   #8 (permalink)
Member: 731904
Thanks Meter: 2
Being that this was copied from my site, Its only fare I post a link to the updated page.....
http://darkforestgroup.com/forum/ind...topic,2.0.html
Old 03-07-2009, 20:16   #9 (permalink)
Member: 358893
Thanks Meter: 33
Sorry l definitely forget to place link in the post, unfortunately not all is copied because links to the download area didn't worked on darkforestgroup, but still BIG THANK TO THE DARKFORESTGROUP FORUMS!
Old 03-07-2009, 20:37   #10 (permalink)
Member: 988844
Thanks Meter: 4
Excuse me for "stupid" question... why? Qualcomm is qualcomm.
Old 03-07-2009, 21:05   #11 (permalink)
Member: 731904
Thanks Meter: 2
Its all fixed now, with new links and some added info. And you are welcome on my site anytime kronos1
The Following User Says Thank You to northwoodinc For This Useful Post:
Old 03-07-2009, 21:48   #12 (permalink)
Member: 938611
Thanks Meter: 43
Permission to add tutorial to Samsung Flash Wiki?
www.samsungflash****
Old 03-09-2009, 20:50   #13 (permalink)
Member: 85127
just incase anyone has problems with the serial port in use error bla bla.. i kept gettin it... so anyways write the bootloader first... when it restarts u get serial port error.... unplug usb... plug into another usb.... then untick boot let it find com an download.. it will write the rest
regards
Old 03-09-2009, 21:24   #14 (permalink)
ringtons's Avatar
Member: 97600
Thanks Meter: 97
so by your reasoning i should be able to flash a LG or Sharp qualcomm phone to a tocco then
The Following User Says Thank You to ringtons For This Useful Post:
Old 03-14-2009, 00:29   #15 (permalink)
Member: 938611
Thanks Meter: 43
I have made PDF format tutorial so that it can be printed off or saved etc.
If you would like to check it out go to
then go to Tools and Tutorials
Wiki Navigation
SGH-M8800
Hope you like and let me know if you do or not
Same goes for the SGH-F480, that's available in PDF too.
Samsung Flash Wiki Admin
GUIDE: How to flash your F480 Tocco WestHej QUALCOMM Models (3G) 1462 03-17-2014 15:11
GUIDE: How to flash TELCEL's i617 jepetu Samsung Flashers, Software, Firmware. 19 08-02-2013 21:14
how to flash m8910 pixon ch_rathore Z3X-Team Products 3 12-05-2009 08:52
How to remove M8800 pixon phone lock? haider UST Pro II 3 02-11-2009 10:05
How to flash a M8800 Pixon chbiz Samsung Flashers, Software, Firmware. 1 01-22-2009 13:01
Page generated in 0.26495 seconds with 10 queries
