Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 03-18-2009, 18:13   #16 (permalink)
Member: 92186
@jtaylor06
You forgot to include theese points on your guide mate:
7. Select Boot Change and Full Download.
8. Then click Boot, and select the boot files from the unpacked firmware folder.
I was getting an error I didn't find out why lol. Then I saw that was the lack of the 2 points
Cheers
Old 03-18-2009, 20:21   #17 (permalink)
Member: 938611
Thanks Meter: 43
Originally Posted by icedome View Post
@jtaylor06
Cheers
Thanks
I'll edit it
Old 03-18-2009, 20:33   #18 (permalink)
bigboy85's Avatar
Member: 682554
Sonork: 1601123
Thanks Meter: 221
hi mates does somebody know if the flash M880 BXXIB3 has spanis language i think it has it, but im not sure can somebody confirm it please?
thanks for your time
Old 03-18-2009, 22:15   #19 (permalink)
Member: 92186
Yap, it has spanish
cheers
The Following User Says Thank You to icedome For This Useful Post:
Old 03-25-2009, 06:56   #20 (permalink)
Member: 953972
Flash not worked
I've just flashed with M8800XEIA2 but now the phone loads up to a blank screen. I can here the loading music, but can't do anything with the phone as it's just got a black screen... Please help...
Old 03-25-2009, 07:30   #21 (permalink)
Member: 953972
New Problem
Hello again.
Finally got the new firmware working. The problem now is that the phone was unlocked before, but now it is asking for a 'network lock' code. Can anybody help?
Old 03-25-2009, 11:03   #22 (permalink)
mistahk's Avatar
Member: 653932
Thanks Meter: 63
Originally Posted by robbosmg View Post
Hello again.
probably was unlocked by some freaky patch, not the proper way with code.. in this case it will always be back after flashing
go to the gsm service you were and tell the to do it properly.
Old 03-28-2009, 14:57   #23 (permalink)
Member: 999028
[quote=kronos1;4217482]OK this is the start and l hope that you all will consider and post any newer information.
4. While holding the no. 9 button on the phones key pad, tap the power button, the phone screen will come on black with a red stripe that says "Download" ( For Tocco and Pixon users : Hold down the "Volume -" button on the left side, and the "Camera" button on the right, then press the "Power" button = all three buttons need to be pressed together. Your phone should start up into a red\blue on black bootloader screen.)
quote]
The "Volume-" button is on the Right side of the Pixonn. I did try it though (pressing all 3 at te same time) and it didn't work. I also tried the camre button and the power button with all other buttons sa combinations and nothing. Please help me,
Old 03-30-2009, 01:18   #24 (permalink)
Member: 358893
Thanks Meter: 33
Press volume down button,then camera button,and while you are holding this two press power on button...and wait for 5 seconds(or until multiloader screen appears) ..
Old 03-30-2009, 09:05   #25 (permalink)
Crazy Poster
Member: 58485
Thanks Meter: 17
I used Multiloader V5.50 for flashing Samsung M8800 with chosen option "BOOT", and now the phone is dead :/
Old 03-30-2009, 15:34   #26 (permalink)
Member: 358893
Thanks Meter: 33
please state the all process of uploading...first time l forget to check the boot and my phone was dead to..but then second time l did it all like in the first post and success everything was ok
Old 04-01-2009, 14:02   #27 (permalink)
Member: 986493
Sonork: topcommunication
Thanks Meter: 10
it works ...but
i full flashed my m8800 the way works perfectly. but my phone still freezed, i cant used the handset . is any one have an idea about this prob
thanks in advance
Old 04-02-2009, 00:18   #28 (permalink)
Member: 358893
Thanks Meter: 33
thanks in advance
well try to flash it again....and do it on different usb plug in your pc
Old 04-02-2009, 12:49   #29 (permalink)
Member: 986493
Thanks Meter: 10
i did . but same thing. what can caused this kind of problem ?
knowing the phone apear normal it read the sim and all seems ok but no touch function
please help
Old 04-02-2009, 23:29   #30 (permalink)
Member: 999028
mate I tried again and again and nothing... either I'm retarded or the keys are wrong.
GUIDE: How to flash your F480 Tocco WestHej QUALCOMM Models (3G) 1462 03-17-2014 16:11
GUIDE: How to flash TELCEL's i617 jepetu Samsung Flashers, Software, Firmware. 19 08-02-2013 22:14
how to flash m8910 pixon ch_rathore Z3X-Team Products 3 12-05-2009 08:52
How to remove M8800 pixon phone lock? haider UST Pro II 3 02-11-2009 10:05
How to flash a M8800 Pixon chbiz Samsung Flashers, Software, Firmware. 1 01-22-2009 13:01
Page generated in 0.40942 seconds with 9 queries
