Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 05-28-2009, 20:33   #46 (permalink)
Member: 358893
Thanks Meter: 33
Here is the newest firmware for M8800 aka Pixon
M880BXXID3
http://www.4shared.com/file/10627891...880BXXID3.html
enjoy
The Following User Says Thank You to kronos1 For This Useful Post:
Old 06-02-2009, 07:36   #47 (permalink)
Member: 1044117
Help! I screwed it up!
Hello there,
Im from Chile and i have recently got a Samsung Pixon (but 8800l).
I've read your guide, and everything went cool, until it ended copiyng files and the cell began rebooting once and again and again and again. Now it's kinda useless...
I think I might be needing a firmware for southamerica, right? In that case, could anybody please update any so I can revive my cell?
Old 06-03-2009, 20:50   #48 (permalink)
Member: 483133
Thanks Meter: 14
great work and nice shirng
Old 06-09-2009, 17:38   #49 (permalink)
.:==di@bila==:.'s Avatar
Member: 254137
Sonork: 1592525
Thanks Meter: 275
Please upload again Multiloader 5.50
Old 06-11-2009, 00:36   #50 (permalink)
Member: 358893
Thanks Meter: 33
New Multiloader 5.56
http://www.4shared.com/file/10866197...ader_V556.html
Old 07-01-2009, 20:03   #51 (permalink)
Member: 870664
Sonork: 100.1614707
Thanks Meter: 53
Originally Posted by foufoutosx View Post
mate I tried again and again and nothing... either I'm retarded or the keys are wrong.
to put your m8800 in download mode just press volume down and power on
that's it
no 3 or 4 keys at ones
Old 07-02-2009, 16:54   #52 (permalink)
Member: 922811
I do not know where to post this...
But the first to say is that this site is awesome...
Second, the unlock procedure to unlock a samsung m8800 with ust pro II is connecting the phone to the e210 cable, just then connect the cable to the box, and then connect the cable to the COMPUTER USB PORT( because of power), before install the usb driver. Just after this click on fast unlock and it is done.
AntoniWilson, first post!!
Old 07-18-2009, 23:01   #53 (permalink)
Member: 358893
Thanks Meter: 33
Originally Posted by rodomiro View Post
Hello there,
m8800l is like f480l and there is a problems with flashing this models,try to look in f480 flash guide to see have there is solution .
but if this helps here is:
M8800L Firmware - Only Works On M8800L
http://www.4shared.com/file/11013235...800LUYIE1.html
M8800LUYIE1
Old 07-18-2009, 23:03   #54 (permalink)
Member: 358893
Thanks Meter: 33
Here is new one,latest firmware for Pixon,please test all main performance like camera(photo quallity,video) speed of ussage in menu and what else...
M880BXXIE1
http://www.4shared.com/file/10884504...880BXXIE1.html
Old 12-25-2009, 02:07   #55 (permalink)
Member: 877401
Sonork: raymond72k4
what the...my m8800 have problem....when i try to boot up it.....then the armss have error then i unplug it from usb cable and try to open it but the screen colored is only red..what should i do?to restore it....also the armss is error in my m8800
Old 01-05-2010, 12:18   #56 (permalink)
Member: 1201120
Sonork: chemistt
rs2 file
M880BXXID3
enjoy
Hi there..:P... I just want to ask about the firmware D3 version where is in-pack
another Rsrc2 file named player...if how it was changer or what does it do....thx
Old 01-20-2010, 00:17   #57 (permalink)
Member: 1213545
OK this is the start and l hope that you all will consider and post any newer information.
First thing to always remember, is BACK UP YOUR PHONE, Pictures,wallpapers,music, and any contacts you have saved on your phone. I am not responsible for any damage to you, your phone, computer, or lost of data in this process. This is a guideline intended for professional technicians.
USE AT YOUR OWN RISK!!!
1. USB cable that came with your phone.
2. Samsung PC Studio 3 witch can be found here:
http://www.samsung.com/uk/support/d..._ia_cd=01011800
Install this software first, it contains the drivers for your phone, and has every thing you need for backup.
3. Multiloader v5,50 http://www.4shared.com/file/75565159...ader_V550.html
5. Newest unbrranded firmware http://www.megaupload.com/?d=B5CXDIOZ
-----------------------------Now you are ready to begin-----------------------------------
1. Make sure Samsung PC Studio is installed and communicates with your phone. And unpack the firmware in a folder you can easily find it.
2. Remove the Sim and MicroSD from your phone and replace the battery.
3. With the phone OFF connect the phone and computer with the USB cable.
4. While holding the no. 9 button on the phones key pad, tap the power button, the phone screen will come on black with a red stripe that says "Download" ( For Tocco and Pixon users : Hold down the "Volume -" button on the left side, and the "Camera" button on the right, then press the "Power" button = all three buttons need to be pressed together. Your phone should start up into a red\blue on black bootloader screen.)
5. Now run MultiLoader v5.33
6. Select the radio button that includes MSM6275/MSM6280.
7. Select Boot Change and Full Download.
8. Then click Boot, and select the boot files from the unpacked firmware folder.
9. Click the Amss, Rsrc1, and Rsrc2.
10. Then press the Factory FS tab, and select the appropriate files from the firmware folder also.
11. Select (Low).r2c NOT (Mid).r2c. (Phone may not restart if you select mid)
12. FOTA and ETC fields are left blank.
13. Click the Port Search button, it will find your phone and show the com port is ready.
14.Click the download button and be patient, this will take a few minutes to complete.
15.When it's finished, it will show "ok complete".
16.Unplug the phone from the USB cable, reinstall the sim, MicroSD, and power up the the phone.
17. Now with every thing complete, perform a hard reset by typing *2767*3855# into the hand set.
18. When the phone resets type *#1234# into your handset to check your new firmware ver.
Need help un-packing the firm ware and having it in a format that works. I just get error codes at the moment and the files are un zipped but un openable help please
Old 01-27-2010, 11:58   #58 (permalink)
Member: 1220007
samsung m8800 pixon
http://freewebcontents.********.com/...800-pixon.html
Old 01-27-2010, 13:36   #59 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,434
hi
my m8800 is bresson not pixson....
i need firmware
i flashed by M8800JPIB5 files but hang on desktop and not work any key's or touch
please help
after conect with multiloader show me BRESSON
Old 01-31-2010, 12:36   #60 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,434
please help...........................
GUIDE: How to flash your F480 Tocco WestHej QUALCOMM Models (3G) 1462 03-17-2014 15:11
GUIDE: How to flash TELCEL's i617 jepetu Samsung Flashers, Software, Firmware. 19 08-02-2013 21:14
how to flash m8910 pixon ch_rathore Z3X-Team Products 3 12-05-2009 07:52
How to remove M8800 pixon phone lock? haider UST Pro II 3 02-11-2009 09:05
How to flash a M8800 Pixon chbiz Samsung Flashers, Software, Firmware. 1 01-22-2009 12:01
Page generated in 0.46508 seconds with 9 queries
