Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 02-26-2013, 13:56   #1 (permalink)
Member: 1089292
help me unlock galaxy s3 SCL21
Hello , i have model galaxy s3 SCL21 made in korea , help me unlock plz
I have z3x box , octopus box
thank all
Old 02-26-2013, 14:47   #2 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
Till now No Box Support This for Unlock ,
Batter ask in Gsm services Boxes Area , If any team have develop any thing will Contact u for Beta test ,
or Move to Buy operator Code ,
The Following User Says Thank You to Mohsin-* For This Useful Post:
Old 04-26-2014, 11:22   #3 (permalink)
Member: 2170499
Sonork: 1654852
i have octupus, z3x,spt butt no one have support
please help..,
Old 12-27-2014, 11:37   #4 (permalink)
Member: 1994598
Thanks Meter: 3
It goes without saying that you full responsibility should you try this. There will be no hand holding. Use your common sense, go slow, make your own notes.
If you are on firmware 4.1.2, the following procedure will open the Service Menu for you.
1. Dial *#9090#
2. Press Menu > Back
3. Press Menu > Key Input then type Q (yes that is correct) and hit OK
4. Press Menu > Key Input then type 0000 (that is four zeroes) and hit OK. Wait a couple of seconds and the Service Menu (DIAG CONFIG) will open up.
Unlocking steps are as follows.
1. Press UMTS > DEBUG SCREEN > PHONE CONTROL > NETWORK LOCK > PERSO SHA256 OFF. Wait 30 sec, then hit Menu > Back until you see NETWORK CONTROL at the bottom.
2. Press NETWORK CONTROL > GCF > GSM/(E)GPRS/WCDMA REL5. Then hit Menu > Back until you see BAND SELECTION.
3. Press BAND SELECTION > GSM > GSM ALL
4. Turn off your phone, put in a new SIM card and see if it worked.
If it doesn't work. Then repeat steps 2 & 3 above but change the selection to SETTING CANCELLATION and DEFAULT BAND PREFERENCE respectively. Turn off the phone, replace your original SIM card, boot and your LTE should be restored.
It should be noted that even if this does work, it will only allow you to use 3G since this phone only supports LTE BANDS 11 and 18. YMMV.
The Following 3 Users Say Thank You to bappysikder For This Useful Post:
Old 04-13-2015, 17:25   #5 (permalink)
Member: 696424
Sonork: 100.1623404
Thanks Meter: 24
I try ... its working good ..how unbelive able ...Thanks bros
Old 04-13-2015, 17:26   #6 (permalink)
Member: 696424
Sonork: 100.1623404
Thanks Meter: 24
no need any box just follow the upper step and get unlock and enjoy..
Old 09-16-2015, 14:58   #7 (permalink)
Member: 2274471
Sonork: 100.1676240
Thanks Meter: 31
If you are on the latest version of 4.1.2 (au released multiple versions) then try *#0011# in place of *#9090# them proceed with the rest of the instructions.
Old 10-13-2015, 17:08   #8 (permalink)
Member: 2195211
Thanks Meter: 4,294,967,295
its really worked for me as use 0011 for unlock
Old 07-23-2016, 09:51   #9 (permalink)
Moderator
Sitlay KING's Avatar
Member: 1483853
Sonork: 100.1611111
Thanks Meter: 1,628
Or more Simple.
Put non wroking simcard
open settings>More settings>Mobile Netwrok>Roaming Settings>System settings>Select GSM/UMTS
For Internet acces you may need to add access point manually.
Thanks
The Following User Says Thank You to Sitlay KING For This Useful Post:
Old 07-31-2016, 06:08   #10 (permalink)
Member: 2605406
Sonork: 100.1674633
samsun note 4 unloking plz
Old 09-07-2016, 18:46   #11 (permalink)
Member: 2181286
Wink Unlock
Octopus s3 *#0808# conection adb
Old 09-12-2019, 06:43   #12 (permalink)
Member: 1514992
Sonork: 27988
Thanks Meter: 4
Originally Posted by Sitlay KING View Post
Or more Simple.
Thanks
thank you working this procedure
Old 10-19-2022, 13:05   #13 (permalink)
Member: 2746928
thank all
Use Z3x Tool For Unlock Fast
Page generated in 0.22961 seconds with 8 queries
