help me unlock galaxy s3 SCL21 Hello , i have model galaxy s3 SCL21 made in korea , help me unlock plz I have z3x box , octopus box thank all |
Till now No Box Support This for Unlock , Batter ask in Gsm services Boxes Area , If any team have develop any thing will Contact u for Beta test , or Move to Buy operator Code , |
Hello , i have model galaxy s3 SCL21 made in korea , help me unlock plz i have octupus, z3x,spt butt no one have support please help.., |
It goes without saying that you full responsibility should you try this. There will be no hand holding. Use your common sense, go slow, make your own notes. If you are on firmware 4.1.2, the following procedure will open the Service Menu for you. 1. Dial *#9090# 2. Press Menu > Back 3. Press Menu > Key Input then type Q (yes that is correct) and hit OK 4. Press Menu > Key Input then type 0000 (that is four zeroes) and hit OK. Wait a couple of seconds and the Service Menu (DIAG CONFIG) will open up. Unlocking steps are as follows. 1. Press UMTS > DEBUG SCREEN > PHONE CONTROL > NETWORK LOCK > PERSO SHA256 OFF. Wait 30 sec, then hit Menu > Back until you see NETWORK CONTROL at the bottom. 2. Press NETWORK CONTROL > GCF > GSM/(E)GPRS/WCDMA REL5. Then hit Menu > Back until you see BAND SELECTION. 3. Press BAND SELECTION > GSM > GSM ALL 4. Turn off your phone, put in a new SIM card and see if it worked. If it doesn't work. Then repeat steps 2 & 3 above but change the selection to SETTING CANCELLATION and DEFAULT BAND PREFERENCE respectively. Turn off the phone, replace your original SIM card, boot and your LTE should be restored. It should be noted that even if this does work, it will only allow you to use 3G since this phone only supports LTE BANDS 11 and 18. YMMV. |
I try ... its working good ..how unbelive able ...Thanks bros |
no need any box just follow the upper step and get unlock and enjoy.. |
If you are on the latest version of 4.1.2 (au released multiple versions) then try *#0011# in place of *#9090# them proceed with the rest of the instructions. |
its really worked for me as use 0011 for unlock |
Or more Simple. Put non wroking simcard open settings>More settings>Mobile Netwrok>Roaming Settings>System settings>Select GSM/UMTS For Internet acces you may need to add access point manually. Thanks |
samsun note 4 unloking plz |
Unlock Octopus s3 *#0808# conection adb |
