the phone suffered a heavy **** broke the touch and I can flash without problem but lost the imei ... lcd works without problem .. But something funny happened .. if I enter download mode but if I press comes up restarts .. thought was the button but it is not. is that I go into recovery and works up and down perfectly .. But if you want to do full wipe when I give Power reset will not let me press .. using a jig asks distort stock recovery rom and put a touch .. and do wipe factory reset etc. .. the fact is that the wifi worked before and even after the coup could call .. over time and I guess I lost imei is related to the efs ... I have Box and I can repair etc ... makes the process but at the final hour when imei write fails (cable UART) recently repair a note 2 without problem) or emmc suspect graphics card that is on the screen but not sure the symptom of buttons gives you any ideas? is curious
