GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   QUALCOMM Models (3G) (https://forum.gsmhosting.com/vbb/f352/)
-   -   how to correctly flash f480 with multiloader (https://forum.gsmhosting.com/vbb/f352/how-correctly-flash-f480-multiloader-898089/)
K1n 01-09-2010 03:58
hi! i have a problem with my f480 and i flash it with multiloader 5.56 and F480XXHD9 firmware the flash finish successfully and i can do everything with my phone without sim card. Now if i turn it off and still turn it on this message appears "DEMSBL BOOT Loader for MSM6280 Downloader Ver 5.32" i reflash it the flash finish with success but if i return it off to put sim card the same message appears. Pls help me how can i do?:confused:
JHUNpanabO 01-09-2010 04:05
try reflash in gsm box.....
Frenzy_2020 01-09-2010 04:46
Multiloader also works nice...tried with several phones
Procedure to do flashing for F480:
First you need to download the firmware you want and then Multiloader V5.33(there is a newer multiloader out plz search)
Preparing your phone:
NOTE: Flashing your phone will delete all your contacts, calender, settings ringtones etc.
You probably want to back up all your files and contacts. I recommend syncing your contacts etc. with Samsung PC Studio and copying over your files on your phone to your memory card or PC (your memory card will not be touched).
Once that's done remove any memory card you may have and then remove the SIM card. Put you battery back in. Your phone shoul be off at this point. Hold down the 'Volume down' key (The bottom rocker button on the left side of your phone) and the camera button and press the power on button. Your phone should start up into a wierd screen with downloader v.5.32 or something and some boxes. It's now ready to be flashed.
Using Multiloader:
* Select the second option from the top (MSM6275/MSM6280).
* Press the AMSS button on the left side and browse to the firmware files you want to flash (unzip/rar them as necessary). Go to the binary folder and then select amss_compressed.
* Do the same for Rsrc1,Rsrc2 and FSS selecting the appropiate files
You should now be ready to flash. Connect your phone to your comp and then click download in multiloader. AT THIS POINT DO NOT TOUCH YOUR PHONE/DETATCH THE CABLE/SWITCH OFF YOUR COMP. Your phone should have a status indicator with percentages and this should be reflected in multiloader. The process should tkae about 5 minutes thgouh I'm not sure about that. Once it's done your phone will restart twice by itself. Once this is done it should start up as normal into the widgets page. It's now complete.
Ps: this is not my work.....I dont want to take credit whatsoever
Frenzy
http://img257.imageshack.us/img257/4...ythanksjpg.gif
K1n 01-09-2010 05:34
thank my brod but i've done all u said but the problem is already there
paddyboy 01-11-2010 16:16
hi i have phone freeze will this cure the problem .thanks in advance pat.
Damsl123 01-12-2010 00:10
GUIDE: How to flash your F480 Tocco
Downloading the software:
First off you need to download the firmware you want and then Multiloader V5.33 which is the program you're going to be using to flash your phone.
F480XEHE1
http://www.mediafire.com/download.php?uykac2jjusd
F480XEHE2
http://www.mediafire.com/?ylcthnu0tyy
F480XEHF2
http://www.mediafire.com/?9w2u40e9m4z
F480XEHF3
http://rapidshare.com/files/12658213...XEHF3.rar.html
F480XXHD9
http://www.mediafire.com/?ttg0mybtzie
This appears to be the latest firmware F480XXHF7
http://www.mediafire.com/download.php?xyyheqh2jkw
F480BOHE3 (branded FW t-mobile) deutsch,english,french
http://www.file-upload.net/download-...BOHE3.zip.html
http://rapidshare.com/files/124143899/F480BOHE3.zip
http://www.dongnamass.com/Samsung/Fl.../F480BOHE3.zip
F488ZHHE8 (chinese)
http://rapidshare.com/files/12588987...ZHHE8.rar.html
MultiLoader_V5.33.exe
http://www.mediafire.com/?czizm9zg32w
Make sure you remember where you've put these files as you'll need to browse to them when using multiloader.
I am assuming here that you've already installed Samsung PC Studio and it works fine with your supplied USB cable.
Once that's done remove any memory card you may have and then remove the SIM card. Put the battery back in. Your phone should be off at this point. Hold down the 'Volume down' key (The bottom rocker button on the left side of your phone) and the camera button and press the power on button. Your phone should start up into a wierd screen with downloader v.5.32 or something and some boxes. It's now ready to be flashed.
Using Multiloader:
Open multiloader. It should look something like this without all the settings selected (The middle section should be blank!):
Originally Posted by .:Morpheus:.
Ok, Morpheus originally selected the wrong option in the top box, you should select the second option from the top (MSM6275/MSM6280). Try firmware F480XXHF7
Then press the AMSS button on the left side and browse to the firmware files you want to flash (unzip/rar them as necessary). Go to the binary folder and then select amss_compressed. Do the same for Rsrc1,Rsrc2 (Rsrc2 MID or LOW? – many use LOW) and FSS selecting the appropriate files as shown in the above pic.
You should now be ready to flash. Connect your phone to your comp and then click download in multiloader. AT THIS POINT DO NOT TOUCH YOUR PHONE/DETATCH THE CABLE/SWITCH OFF YOUR COMP. Your phone should have a status indicator with percentages and this should be reflected in multiloader. The process should take about 5 minutes though I'm not sure about that. Once it's done your phone will restart twice by itself. Once this is done it should start up as normal into the widgets page. It's now complete.
Congratulations on flashing your phone. You can now replace your SIM and Memory card and set up your phone the way you like it.
Damsl123 01-12-2010 00:23
I'm sorry but I couldn't add any screenshots to the above post so I hope it makes sense.
It was a long while ago when I did this so I'm not even sure the links will work either but maybe you google some of the link names i.e. multiloader v5.33.
Oh may I add I do think you need to use multiloader v5.33 and NOT v5.56 - well I would just to be sure I'm using the right one, i don't know - just a thought!!
Sorry I couldn't be of more help
LEENO 01-14-2010 13:25
F480XEHE1
F480XEHE2
F480XEHF2
F480XEHF3
F480XXHD9
F488ZHHE8 (chinese)
Using Multiloader:
Thanks friend but
LINK FOR F480XXHF7 and downloader not work, please reupload
Grupo MovilFree 09-17-2010 15:45
Info
Can any body re-upload?
Regards
axecom 03-17-2011 17:34
F480XXHF7.rar
khan_GSM 04-07-2014 08:15
thanks bro
http://i57.tinypic.com/10mkmsn.jpg
networking mobi 01-26-2015 10:15
f480 flash ok this file F480XXHF7
Page generated in 0.21934 seconds with 6 queries
